Thread: Modified 2.5 gallon chlorine jug
    Aug 2014
    Seminole, FL
    92
    I get my chlorine from pinch-a-penny in 2.5 gallon jugs. When they are full and I try to pour out into my measuring jug, I get chlorine every where.
    Here's my solution. I bought a plastic faucet off Amazon that has washers and a locking nut, drilled through one of the spare jug caps and hey presto! Works good so far, but don't know what 10% chlorine is going to do to the soft rubber washers over time, although I'll only use the modded cap when I need to add CL. It needs a relief vent but I can't drill through the back of the jug, as I need to exchange it for a fresh one.
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Modified 2.5 gallon chlorine jug
    Hey, that's handy.
    Essential Links:
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Love the upside down label warning "do not tip"!
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
