Thread: Quick Question on lowering PH
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Cool Quick Question on lowering PH
    Today's numbers.
    pH 7.8
    Chlorine 4
    CC0
    TA 100
    CH 120
    CYA 30
    Water is sparkling and 78 degrees, the leak is fixed and the new skimmer line works like a charm
    My pH has crept up and i need to lower it. Should i go down to 7.2 in 2 steps?? or just shoot for 7.4?
    TA is 100 which is a touch higher than past years but has been stable this year. How much will it be impacted?
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Quick Question on lowering PH
    How confident are you of your pool's volume?
    If you're certain of it, there's no reason not to target 7.2. If there's any doubt, aim a little higher.
    If you plug all your numbers into poolmath to get the acid dose and then scroll down to Effects of Adding Chemicals, you can enter the acid dosage and it will tell you how much it will impact pH and TA. Bothe are an approximation, so don't be alarmed if the pH drop isn't exactly what the calculator above figured.
    Nov 2011
    Albany, NY
    495
    I am 99 percent confident so i will do 75 percent to start. Thanks !
    Haywood Sand Filter
    Vinyl Liner
