Thread: HAYWARD Diver Dave
    Apr 2013
    Argyle, TX
    77
    HAYWARD Diver Dave
    I have a 4 year old Diver Dave cleaner that I use with limited success in my old 18' Intex pool. We had the power to run him with the Waterway sand filter we had and I believe he would have been much better if the pool floor was flat and wrinkle free.(floor was a lumpy mess due to moist ground under)
    My question is should I keep using it in my new pool or get something else.
    I did buy brand new shoes for him.
    My new pool was professionally installed with a flat wrinkle free bottom
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: HAYWARD Diver Dave
    We have lots of AG owners I am sure will pitch in with suggestions. Good luck!
    Essential Links:
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I have the equivalent in Wanda the Whale and she does a fine job. I think you will find that "Dan" does a much better job in your new pool because the pump is probably stronger than it was in your Intex pool.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
