Thread: In Floor Cleaning
    May 2015
    Houston TX
    49
    In Floor Cleaning
    We will have the inground Paramount cleaning system. But was surprised when our pb said the other day that we will probably have to vacuum up sand from the bottom. What ? If that's the case, may need to rethink this Paramount system. But then we may be stuck with it. They're getting ready go dig, and the pb has already sent off to Paramount for their drawing.
    Houston,TX, IG 15120 gal, gunite, 22' x 36',wet edge finish, Pentair equip, 420 cartridge filter, vs pump, Intelliflo vs booster pump for water features, 400,000 heater, auto fill ,PCC 2000 in floor cleaning ,2 LED lights,travertine coping, paver decking, 9x12 tanning shelf ,1 LED color bubbler, 2 5' benches w jets. Depth 4- 4 1/2- 5 , wall with 3 24" sheer decent , 2 spray heads, Intellitouch Controller.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Re: Do I need a Robot?
    Magicruiser: It's YOUR pool!!!! He was at fault for not explaining that sooner. He can return whatever he's already ordered. You should still be safe if the dig isn't finished.
    I'm like you. What's the point of the expense if you still have to manually vacuum. There are too many other options. Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    38,301
    Yup, I had to vacuum my previous pool that had an in floor system. I would not get one again .. Plus you use a lot off electricity running a big pump.
    Oct 2013
    Spring, TX
    87
    Our Paramount PCC2000 keeps the floors clean. If a clump of dirt falls in, the cleaning system will take care of it. If you're impatient, you can just brush it towards the main drain. There's no sand in my pool, and there's no reason to vacuum. The only time you'd have to vacuum is when someone accidentally dumps a wheelbarrow of mulch in the pool.
    15k gallon IG, 36' x 15', built April 2015, Pebble Sheen
    Pentair CCP420 cartridge filter, Pentair EasyTouch 8 controller, Sta-Rite Max-E-Therm 400K Heater
    Sta-Rite IntelliPro VS pump, Sta-Rite Max-E-Pro 1HP & 2HP pumps
    Paramount PCC2000 ICS, TF-100 w/SpeedStir
    May 2015
    Houston TX
    49
    Re: In Floor Cleaning
    Thanks for your comments. I don't want to spend the money for the system. But my husband says, when we're out of town it'll clean itself, and not have to come home to a dirty pool. He doesn't want to use a pool service. He wants to keep the gate locked. So much for my patio furniture!
