Thread: Omnilogic and Heatpro 21404T
    Aug 2014
    Eldon, MO
    6
    I cannot seem to get my omnilogic and heater to communicate, which I imagine is in the settings of the Heater. Does anyone have any experience with getting the two to communicate so i can adjust the temperature from Omnilogic? Thanks!
    38,260
    Re: Omnilogic and Heatpro 21404T
    Sorry for the lack of response, but I have no help either.
    Have you read the heater manual about how to use an external controller?
    Aug 2014
    Eldon, MO
    6
    Jason thanks for the reply. I did get it fixed this morning after talking with Hayward I needed to delete the heater from omnilogic and reconfigure it. Works fine now!!! Thank you
    Hold "set" button on heater for about 5 seconds until you see "Loc"
    Then press the up arrow button until you reach 50 degrees
    Set pool temp to off
    Set spa temp to 104
    Scroll "set" button til u get to the P_S section, then arrow til you get to "E"
    That should put it in bypass mode
    20x40 Vinyl Lined Polymer Wall Pool 8 ft
    Omnilogic Automation/EcoStar Pump/Hayward Filter
    T-Cell 15 SWG
    Heatpro Heater
    Sense-Dispense w/ Acid Feed
    38,260
    Glad you got sorted. Thanks for posting the solution.
