Thread: Muriatic Acid or Ph down?
    May 2015
    Mississauga
    29
    Hi
    My Ph is 7.8 which is not high but I would like to lower it a little. Should I use MA or some PH down which I have from last year? I read pool chemistry which says I should use dry ice or PH down. Any help would be great!
    11.5K gal, IG vinyl, 3/4 HP Hayward Pump, Hayward sand filter, Hayward Chlorinator (Turned Off), Raypak Heater, Taylor FAS-DPD K2006C T/K
    30,432
    Re: Muriatic Acid or Ph down?
    Muriatic is the purest and the best but pH down will work as well with little side affect.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    +1 on MA is the best.
    Here is a great article from Pool School about, Recommended Pool Chemicals, what they do and how to add them.
    May 2015
    Mississauga
    29
    Thanks!
