Thread: High CH, Fiberglass Pool
    Apr 2015
    Denham Springs, LA
    44
    Is high CH (375) an issue with a fiberglass pool?
    19,800 gal fiberglass pool; Hayward Pro sand filter (S244T) w/ vari-flo xl valve; 1.5 hp challenger pump; Aquarite SWG w/ T-15 cell; Dolphin DX3 auto vacuum; TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: High CH, Fiberglass Pool
    It could an issue be if the pH and TA were allowed to get too high. Under the right (wrong) conditions, scale can form on the walls. It's like grow-your-own sandpaper.
    I, personally, don't consider 375 high at all. In the five years I've owned my pool, I've never been that low. It just requires a little more care. Post your test results and you can get some specific advice.
    Apr 2015
    Denham Springs, LA
    44
    Coming down from a SLAM, still dialing in my SWG % and pump run time:
    5:45pm yesterday:
    FC 4.5
    CC 0.0
    TA 80
    CYA 50
    pH 7.5
    salt 3000
    Added 4 lbs stabilizer and 40 lbs salt to raise my CYA to 75 and salt to 3200. Let pump run overnight, w/ SWG set to 100%, to mix.
    06:30am today:
    FC 7.5
    CC 0.0
    salt 3200
    didn't test anything else.
    Richard320's Avatar
    Jan 2010
    19,051
    When I plug your numbers into poolmath, and call the water 82F, CSI is -.26. There's no risk of scaling when the number is negative.
    Apr 2015
    Denham Springs, LA
    44
    Thanks, I saw that too. Although the water temp is closer to 90. Just wanted to double check.
