Thread: Backwash into French Drain
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    Does anyone here run their backwash hose to a French Drain? I was curious if that was OK to do and if there are any problems associated with doing that.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Mar 2007
    Coastalish 'down easter'
    Re: Backwash into French Drain
    It's fine to do as long as local codes don't require used DE to be reclaimed (DE is a carcinogen and some localities won't let you dump it into a sewer or even on your own property ) Just check to make sure that you can legally dump it on your own land.
    Also, if you haven't seen it already, you might find some useful info on Use and Care for a DE filter here
    Luv& Luk
