Thread: Chemical makeup
    Jun 2015
    Bessemer,Mi
    42
    Chemical makeup
    What is the powder used to test FC?
    i can't find it anywhere. Chemical name
    and what are the Two reagent chemicals
    Taylor k 2006
    16x48 intex ultraframe. 5300 +or-
    cheapo intex filter for now.
    Taylor k2006.
    Working on the partial wrap around deck
    NEED to add a skimmer!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Chemical makeup
    You can get refills from TF-Testkits, see the link in my signature
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Chemical makeup
    The R-0870 is N, N-diethyl-p-phenylenediamine (DPD), powdered indicator dye plus phosphate buffer, EDTA and organic acid
    TF-100 storage and chemical names question
    Here's the Taylor MSDS sheets http://www.taylortechnologies.com/pr...&Number=K-2006
