Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Homemade Skmmer
    May 2015
    Chicago, IL
    508
    Homemade Skmmer
    Here is pics of the homemade skimmer. The right pipe sucks in, and has a p trap to prevent air getting sucked in. The left pipe is set in such a way it makes the water rotate in a clockwise manner, bringing everything to the suction on the skimmer.
    I should also note, this is a separate pump from the main one. So there is two of these pumps in the pool. The one that came with it, and the skimmer one, which is on the opposite side of the original.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Homemade Skmmer
    Nice work Ozzy!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Thanks. I think it works much better than the hanging basket skimmers, or the thru-wall ones I have seen for Intex pools.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Homemade Skmmer
    The over the wall ones are horrible. I am liking my Hayward through the wall, but I think your set up would be even more efficient.
    Lisa
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    I think it is also. IMO the key is the way the output port is going. You can actually float something in the water and watch it go clockwise around the pool. it takes about 1:45 to make a complete trip.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Homemade Skmmer
    Yeah, good work. Circular water circulation does seem to be the key to keeping the surface moving and clean. That is some plumbing/pool engineering genius!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Homemade Skmmer
    It looks like the sink strainer might accommodate a standard vacuum hose. True or false? And is the one hooked to the filter the same?
    30,403
    Re: Homemade Skmmer
    Hey! What's This?? The new guy on the block showin' up us old timers?
    DFW, TX
    24,450
    Re: Homemade Skmmer
    LOL!! I'm not old, I'm seasoned!
    That is some TFPC-clear water!
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Homemade Skmmer
    Looking at the pictures again, I can easily visualize a pool noodle clamped onto the return jet to make the ultimate water cannon. Just loosen the locknut and swivel the return up out of the water and blast away.
    Jun 2015
    Bessemer,Mi
    42
    Re: Homemade Skmmer
    Did u put an actual filter inside or did u make a basket screen of some sort?
    16x48 intex ultraframe. 5300 +or-
    cheapo intex filter for now.
    Taylor k2006.
    Working on the partial wrap around deck
    NEED to add a skimmer!
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Actually it is a offset floor drain, but I could probably make it so a vacuum hose could attach to it.
    LOL, just a little bit of backyard beer plumbing.
    Quote Originally Posted by Hendu2875 View Post
    I am using the actual filter, I don't get alot of big stuff floating in the pool, just cottonwood and bugs.
    Jun 2015
    Bessemer,Mi
    42
    Re: Homemade Skmmer
    Yup. That's my next project. Love DIY stuff. As soon as I lay these last few deck boards!
    i have that exact pump I got from someone who was using it for a small pond lol
    Taylor k2006.
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Once you set it up, it will out preform any store bought skimmer you can get for a intex.
    Jun 2015
    Bessemer,Mi
    42
    Re: Homemade Skmmer
    Did u need to retrofit the 1 1/2" PVC to fit the pump?
    Taylor k2006.
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Yeah, I used 1 1/4 x 1 1/2 inch trap adapters.
    Jun 2015
    Bessemer,Mi
    42
    Re: Homemade Skmmer
    WORKS like a charm!!!! She's done
    Taylor k2006.
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Have any pics?
    Jun 2015
    Bessemer,Mi
    42
    Re: Homemade Skmmer
    I can't post pics from my phone. Too big
    Taylor k2006.
  20. Back To Top    #20
    May 2015
    Chicago, IL
    508
    Re: Homemade Skmmer
    Just a update on this. It is amazing how well it is working. The pump/filter that came with the pool barely needs to be cleaned. The skimmer pump/filter needs to be cleaned twice a week. It is interesting on all of the crud I have to wash out of the filter. I would suggest to anyone to do a similar setup with their intex pool.
