Thread: New Hot tub owner
    Jun 2015
    Goldsboro
    2
    New Hot tub owner
    We just acquired a used 2001 Baja Performance Series Hot Tub and once having an electrician hook up the power we are having a couple of issues with it. First question is : Main jets are working great but the small jets at each seat are not working, any suggestions as to what the problem could be? and Second question is: Not heating up, any suggestions on this? My control panel shows that it is heating but not getting up to set temperature.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Hot tub owner
    Is this your tub? http://www.spaparts123.net/files/200...ers_Manual.pdf
    found on this page Baja Spa Manuals
    some hot tubs have some kind of valve that when turned sends water to different jets.. look on page 13 for operation
    you would need to have the heater checked out but it sounds like it has gone bad or is so corroded that its not able to heat like its suppose to..
    Spa Heater Elements
    you might be able to call them and ask about the heater..
    hope this helps
