Thread: Doing repairs -- How to release water from solar collectors/panels (without wasting)
    Jun 2013
    Bay Area, Calif
    18
    Hi folks,
    Pretty standard in-ground pool setup:
    I have a leaky three-way valve/manifold that I'd like to replace the gaskets/o-rings on. Additionally, a bit of a leak in one of the ABS pipe unions/connectors. I'm looking to do some fixes, but will need to release the water from the solar collectors back down to the pool. Is there an easy trick folks may recommend? We're in drought country (California), so would like to conserve as much of the water accumulated in the solar collectors as possible.
    I was thinking about heading to the roof and opening up the system at the relief valve to break the vacuum to purge the system, but if there's an easier way on the ground, I'd love to try it out!
    Thanks
    Apr 2008
    StL, MO
    49
    Re: Doing repairs -- How to release water from solar collectors/panels (without wasti
    No advice, except that once you figure out how to do it, be sure to plumb in a dedicated drain line and valve for the future. Good luck and let us know how you solved the problem!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    So, your 3 way valve isn't a solar valve that has a small hole and drains back after the valve is closed? How about manually opening the 3 way valve? That should allow it to drain down.
    Jun 2013
    Bay Area, Calif
    18
    Quote Originally Posted by pooldv View Post
    Beautiful, thanks, that did the trick!
