Thread: Another new member from Texas
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Greetings all.
    We just re-located to Texas accepting my dream job (working for Nike Golf) from Ohio and of course had to buy a home with a pool with the long swim season and periods off 100ΒΊ plus temperatures. We love the house and love the pool but it is too cold to swim right now, but darn does it look so inviting.
    Anyway I have been reading lots of great information right now and look forward to learning much more. This is my first in ground pool. As you can see from the picture it is a Roman style and is 23' x 15' measuring the rectangle. Not sure of the total gallons yet because as mentioned it's to cold to go in. Does anyone know of any web sites listing Roman pool specifications? Reaching in as far as I can i looks to be 4' in the shallow end and deeper maybe 4-1/2' to 5'.
    The home was empty when we bought it and they had a pool service but they had the Chlorine really cranked up. The chlorine feeder was set all they way up and the FC was above 10 TC was the same. I turned the feeder down to 3 but when the chlorine never went sown I turned it all the way down. I will give the BBB method a go but for now I need to wait for the levels to go down.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Another new member from Texas
    Hi AV8TOR and welcome to TFP!
    Beautiful pool!
    You're done SLAMing when:
