Thread: IC40 false high salt light
    What would cause the high salt light to flash when the salt is not high? The board says salt level at 9900ppm!
    All other lights on IC40 are green. FC at 1.5.
    I tested using a salt strip and reading was 750ppm! Shouldn't it have shut off at that level?
    The IC40 was just installed last fall.
    Pool guy came out last Saturday and said it was working fine. Obviously not.
    Salt = 830
    FC = 1.5
    TA = 120
    CYA = 30
    26K, IG vinyl, Intelliflo VST 2, Intellichlor IC40, Tagelus TA60 sand filter, Pentair Easy Touch Control Panel, Automatic Pool Cover
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,481
    Re: IC40 false high salt light
    It could be a bad cell, but I doubt it. The cell needs about 2800 ppm of salt to work at all, with 3400 being the ideal measurement. 750 or 830 ppm is so low that I would suspect that the Easy Touch just sees it as an error. I'd add the necessary salt to bring it up to 3400 (using a salt test kit or strips), let it run overnight, and see what the IC40 reports the next day.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Please update your location so we can see what climate you are in. What is the water temp?
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    I wonder whether you might want to use a more accurate salt tester.
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
