Thread: help!! my intex 14 inch sf15501 pump is leaking under pump
    bjohnson541's Avatar
    Jun 2015
    Harriman tn
    6
    Hey guys I need some help. I've had this pump 3 yrs now. It's a 14 inch intex sf 15501 model. I noticed a continuous wet spot under the pump and filter. All connections are dry. My pool is a 16 ft summer escapes round pool. I'm having to add water every 2 weeks which messes up my levels. I also noticed that there is a continuous air bubble in the strainer pre filter. Any suggestions would be appreciated. ...
    Jun 2015
    Harriman tn
    6
    Re: help!! my intex 14 inch sf15501 pump is leaking under pump
    Quote Originally Posted by bjohnson541 View Post
    I made sure to lubricate the oring on the strainer basket.
    Jun 2015
    Harriman tn
    6
    Anybody?????????
    Mar 2015
    New Orleans, LA
    81
    Don't know that pump but could be the seal in the pump. Try tighten everything on pump and if that does't work, might need a new seal.
