Results 1 to 16 of 16
Thread: PH keeps falling
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    PH keeps falling
    Why does my PH slowly keep drifting down?
    Seems I have to add atleast a cup of borax every 4-6 days to bump it up.
    Lomart 18x48 AGP 7000Gal
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    TF-100 w/Speedstir!
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: PH keeps falling
    Could you post test results?
    What is your TA?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Tc 5
    fc 5
    cc 0
    ph 7.3
    ch 50
    ta 80
    cya 40
    TF-100 w/Speedstir!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by AimeeH View Post
    What is your TA?
    ...and your source of chlorine?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Bleach....of course
    TF-100 w/Speedstir!
    Apr 2015
    Quinlan, tx
    811
    following this thread as I'm trying to learn as much as I can. Good luck. These guys are awesome and will fix you up!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    That is a little weird for me. I almost always see rising PH and am much more versed in how to deal with that. But, you do have a few choices that I am aware of, I just don't have any experience with them or know what works better because I also have rising PH.
    Raising your TA slowly with baking soda until PH stabilizes, like 10ppm a week or so.
    Continue raising your PH with Borax until you have enough borates to stabilize your PH.
    Add enough Borax to raise borate to 50ppm right now.
    Here is an article about borates, Borates - Why and How
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Thanks pooldv, what should my TA be? I thought 80 was good.
    Quote Originally Posted by Pogueld View Post
    Thanks, I'm trying to learn as much as possible also I have been really enjoying this community
    What is the pH of your fill water? If it has low or neutral ph, every time you replace water lost to evaporation and splashout, it would lower the pH a tiny amount.
    Does the pH mainly drop after a rain? Up here in the Seattle area, we occasionally get acid rain coming from the industrial areas to the north (Everett, WA to Vancouver, BC). Perhaps you're getting rain filled with acidic stuff drifting south from Albany and Portland?
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    DFW, TX
    24,450
    Quote Originally Posted by mnasholm View Post
    TA is not a number that really "should" be something. It is a combo of things (fill water, pool surface, age, PH) and finding the range that ultimately makes your PH stable. TA can be anywhere from like 60 to stop rising PH to around 120 stop falling PH. And PH can be anywhere from 7.2 to 7.8 if it stabilizes there.
    There are people here with and without SWG who have not adjusted their PH in years because their fill water, CH, TA are all in a sweet spot. I'm jealous! Getting my PH stable is going to be my summer project.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Got it back up to 7.5 and TA of 80-90, we'll see how that does
    TF-100 w/Speedstir!
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Fell about .1 every day this week. Just added 2 more cups of Borax......super weird
    TF-100 w/Speedstir!
    DFW, TX
    24,450
    It is weird. You might be the only one here right now raising PH. Why be normal, eh!
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Thats how we work here in Eugene, OR haha.
    Guess I'll just keep adding borax, Heck I'm getting borates out of this haha.
    Question though, this is slowly adding TA too right? If so what do I add instead if the TA gets too high?
    DFW, TX
    24,450
    You are getting borates out of the deal. I am a fan of borates. Borax raises TA least of the chemical options. Raising your TA is not bad. There is a good chance that adding borax to raise pH and TA will eventually get you to a point of homeostasis on your PH. If that happens with TA anywhere from 80ish to 120ish then that is fine. You can also raise PH with aeration with no impact to TA
    See the raising PH section on this page for more info.
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Perfect, Thanks pooldv
    TF-100 w/Speedstir!
