Thread: re Deck Options, Pros and Cons
    Jun 2015
    Covington, LA
    1
    Quote Originally Posted by SeanB View Post
    There are a lot of choices out there when it comes to pool/patio decks. I thought it might help people decide what type of decking would work best for them if we listed some of the pros and cons of each type with examples.
    So, if you could, just post a picture and any pros and cons you can think of.
    I'll start:
    Sundeck
    Pros:
    It is easy on your feet/slip resistant, comes in various colors, and is fairly durable - can be gently pressure washed and doesn't stain too easily. Also, it can be applied to new or existing concrete.
    **Grain of salt - We have had our deck for less than 6 months so time will tell if these claims hold to be true.
    Cons:
    Somewhat expensive. In south Houston, cost was $9 per sq ft. Can be damaged if pressure washed under high pressure. Costly to add to existing deck at a later date.
    Overall look:
    Close-up:
    Here is a link for more info:
    http://www.sundek.com/
    what color sundek is posted in this picture please?
    Re: Deck Options - Pros and Cons
    SeanB,
    We used Travertine for 3,000 sq.ft. and Belgrade pavers for about 400 sq.ft. and Trex walkway along the water
    Travertine:
    Stays cool in high temp areas
    The look we wanted to achieve
    Durability and easy to replace
    Con
    Cost
    Weeds may grow in the cracks and have to be killed
    Belgrade pavers get hot
    TsTime's Avatar
    Jun 2015
    San Diego CA
    16
    We are choosing poured concrete with a Top Kast 3 treatment to barely expose aggregate.
    Pros: Cost, low to no maintenance, easy of the feet, love the look!
    Cons: Can't think of any for us
    In design and proposal stage: 46'x10' - 2ea 2'x10' 8" & 12" deep Baja Steps - 4-7' Deep - 2 Sheer Descents - 15,000 gallon in ground - Automatic Cover (under coping)- SWG - 400,000BTU NG Heater - Unknown size/brand pump(s), filter, LED, cleaner type and pool finish
    Jun 2015
    Fonthill
    6
    Unhappy Liquid Solar Cover... what if it's too good?
    I'm debating on getting the Heatsavr product for our new inground pool and have concerns...
    • Does it work?
    • Does it work too well?
    • What do I do if the pool get's too warm... you can't "remove" it?
    I like my pool at around 78 degrees. In our previous home (also inground pool), when the pool temp got too warm, we would leave the cover off at night and even that would sometimes not be enough to cool it down overnight (we are in Niagara Region of Canada). I'm concerned that during the peak of summer, the liquid cover, though not as good as a traditional blanket, will still cause too much heat to become trapped and drive up the temp.
    If I stop adding the product, how long does it take for the blanket to become "ineffective"? I thought that perhaps when we get to the hot days of summer, we could simply stop adding it which would be just like "removing the blanket"....but it does me no good if it still works for a week before dissipating.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I want what Martin Kennedy has!!!!! Oh wait, ya'll are only talking decks? Ok, I'll take his decks and everything else, too!!!! And I second what Amanda said. Suz - in dreamland.
    P.S. I'm curious about many of these decking materials that I'm not familiar with. Pictures please, when you get a chance! Thanks! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
