Thread: Bonding this weekend- roundtrip or terminate???
    May 2015
    Lafayette, La
    7
    Weather permitting , everything showed up this week to bond ,went with the Permacast inline for 1 1/2" HP for water..all copper everything else.
    So , I trench out around the pool , question is do I round-trip the whole system ?
    Meaning start at the pump go up to the Aqua Trol -down to the Permacast inline -then out to the pool creating a halo /contacting frame -then return back to the pump.??? full circle??
    Or do I halo around the pool and then run a separate lead to the SWG , Permacast , and terminate at pump?? off of the halo?
    32 x 16 Doughboy Desert Spring 2 ft in the ground, Hayward S210T93S Pro Series 1-1/2 Hp pump , Fairmount sand , Aqua Trol SWG, Morton salt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Bonding this weekend- roundtrip or terminate???
    HI home pool.
    Halo around the pool, then continue it to all of the equipment at the pad. No roud trip required. Just end it at the last piece of equipment. Thats all you need to do.
    hope this helps,
    Divin Dave,
    May 2015
    Lafayette, La
    7
    Thank you very much DD..
    No digging today though , raining hard and looks to be all day event..
    Eric
    May 2015
    Lafayette, La
    7
    Well , got it done , with the ground damp it was easy to dig but turned into a a mess , shoes felt like 10lbs a piece ,slip and slide..
