Thread: Leaking Intex
    Jun 2015
    Bow, WA
    1
    Leaking Intex
    We have a 15' Intex with inflatable ring. It was brand new last summer with no leaks. I put it away dry and clean last fall (and away from where kids could reach it in the garage). I set it up last night and began filling and with a couple inches of water in it it began leaking from underneath. I inspected it before filling and did not find any holes. Could it be leaking at the seams? Any ideas on how to find the leak would be appreciated. It is a bit unwieldy. Thanks!
    Re: Leaking Intex
    It could just be condensation if you don't see it squirting out of a hole or seam. See what happens after a day or two. . .
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Mid Missouri
    227
    Re: Leaking Intex
    Ours had a leak the third year we set it up. Like you we noticed a puddle with a couple inches of water in the pool. I got in the pool and pulled from the top of the sidewall to "roll it back". We dried the area up, and let it back down. Waited a few minutes and rolled it back again and were able to narrow down the location of the leak. Once we had a good idea where it was at, I pulled it back just past the point where we thought it was and the wife zeroed in on it from where the water was coming thru, and I found the tiny speck on the inside. A couple things that worked in our favor; our leak (pinhole) ended up being fairly close to the edge, and my pool is set up on top of polystyrene so the puddle was easy to dry up then locate. If yours is on a tarp, I assume that would be about the same.
