Thread: Upgrading from flow master pump to intex 2100
    Jun 2015
    Ecru MS
    1
    Question Upgrading from flow master pump to intex 2100
    I want to upgrade to a sand filter pump instead of flow aster pump that came with pool. My question is ...will the intex 2100 work on my pool before I order it?
    Coleman 18x9x48" rectangle frame above ground pool 3,913 gal. W/flow clear filter pump
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Upgrading from flow master pump to intex 2100
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2016
    Forest Hill, La
    3
    I have the coleman 18x9x48 pool. Holds 3913 gallons… My question is- We are looking to upgrade to a sand filter pump instead of the junky 1500 filter pump that came with it. Will the intex fittings work for it… And also, should we buy the 4000gph or will the 3000gph work?
