Thread: Hayward Filter and drain question
    Jun 2015
    Genoa city, wi
    10
    I am a brand new member who has enjoyed the benefits of reading the TFP information for quite some time but has never posted. So let me start by saying that I have read as many posts and pool school posts/threads as possible, but I am not finding what I am looking for (most likey because I don't have the right terminology to search?) so I apologize if there is a post for this problem that I missed and if these questions seem beyond basic. That being said, here goes: I am obviously new to pool ownership. I recently opened my small pool, which I purchased last year but was set up by the installers. So...I think there should be to photos with this post. 1) everything seems to be running fine, I have some water leaking out of the lock rings on the filter lid when the pump is on. Is it because I don't have it screwed on all the way? If so, how do I make it tighter. I have tried depressing the safety lock clips and pressing down and turning it more, but nothing happens. Do I need to take the lid off and start again, and if so, how do I do that without water flying everywhere. I don't think I have a handle to shut off the water going into the chlorinator thing (NatureVisionPro) nor do I have one going from there to the pool outlet. I would really, really appreciate anyone's help! And don't worry, I am not offended if anyone is laughing at, what is most likely, a really dumb question. Thanks ahead of time!!
    12' x 52" AGP
    Hayward Voyager SwimPro (cartridge) w/nature VisionPro
    & Hayward Powerflo pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Hayward Filter and drain question
    Welcome!
    You can stop the water by whittling down a potato or a carrot and cramming it in the openings inside the pool. Then drain the water out the drain plug on the filter. Then open the top and check the big O-ring. It should be free of nicks and cuts and grit. It should feel greasy. If it doesn't, you want a tube of pool lube from the <gasp> pool store or some silicon grease from the hardware store. Get that big O-ring all slimed and reinstall it and try cinching down the lid again. Reinstall the drain plug and remove the vegetables.
    Jun 2015
    Genoa city, wi
    10
    Thanks for the speedy reply.
    Last edited by Gizelle; 06-12-2015 at 07:13 PM. Reason: I am an idiot and posted in the wrong place
    12' x 52" AGP
    Jun 2015
    Genoa city, wi
    10
    Thank you so much for such a speedy reply and for such a quick and easy solution.
    12' x 52" AGP
