Thread: My thoughts after using Paramount PCC2000 In-Floor Cleaning system for 6 months
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    INTRODUCTION
    In general, there seems to be a dearth of detailed information on the performance of in-floor cleaning (IFC) systems. I’d like to share my experience after using my IFC for the last 6 months or so.
    My wife disliked the Polaris 280 we had at our last house and hated the way it sprayed the windows and got tangled up in the kids when they were swimming (she really hated to disconnect it when using the pool). So in my recent pool build, I went with the Paramount PCC2000 system. My pool has 2 skimmers (Skimmer #1 is in parallel to the MDX floor drain and is part of the filter loop; Skimmer #2 is the water source for the IFC nozzles.) I also have 4 pumps: 1 for the filter loop, one for IFC loop, and 2 for various water features.
    IFC DESIGN
    When a PB is desiging a pool, they send the design to Paramount who specifies number and location of nozzles, number of zones, etc. The hard engineering part is left to the engineers, and the PB’s plumbers just have to follow the instructions.
    In theory, the PCC2000 system is designed to work like this: There are various pop-up nozzles in the floor, on the steps, on the benches, and on the sun shelf. My pool has 6 zones. When a given zone is on, the heads pop up and spray relatively high-pressure water for about 30 or 40 seconds and then go back down. The next time the zone is active, the heads rotate slightly and spray in a different direction. During the transition time between zones, the previous and next zones are both active at the same time, which is a change from older-style systems that would turn off one zone before activating the next zone, which resulted in high-pressure fluctuations in the IFC plumbing.
    I have a very large MDX drain in the center (deepest part) of my pool that collects all the debris sprayed by the nozzles. To maintain VGB compliance, there is another “drain” on the side wall, under my waterfall. The MDX drain feeds a debris canister built in to my pool deck, which then feeds the pool filter. So basically, all the dirt on the pool bottom goes into a net to filter out the big stuff and then into my filter. The debris canister can be opened and cleaned (very similar to a skimmer) in about 20 seconds. Most of the time, the filter screen net has bugs, a few leaves, some pebble from my pool surface, and tons of dog hair (my Labrador Retriever can’t say out of the pool!) Interestingly, when opening the lid it appears that there is stagnant water on top of the internal lid, but Paramount assures me that 2-3 gallons per minute of water actually circulate through this reservoir. After watching it in operation, I think I agree. And besides…my pool water reaches 90°F during the day, and there is no visible evidence of anything growing in there!
    After the filter, the water is returned to my pool through the various jets on the walls of the pool. These are not typical directional jets; each one is directed down and washes water down the pool walls towards the floor. This helps drive water currents towards the bottom and, ultimately, to the MDX drain. In addition, when the pool filter pump is running, there are 2 static pop-ups near the center line of the pool that continually push high-pressure water towards the floor drain. These are continually operational, even if the IFC pump is off.
    Right now, I’m running my main filter pump 6-7 hours per day (dictated by SWG run time needs), and my IFC pump is running about 1.5 hours per day (haven’t adjusted since January). These run times are programmed into my pool controller.
    OBSERVATIONS
    In general, the system works as intended. I haven’t used any other method of cleaning my pool floor, and it’s generally spotless. There is 1 spot under my waterfall that tends to collect some “dust”, but it eventually gets washed away. I would say that I’m completely happy with system performance. My pool bottom is clean, and I have to spend zero time and effort to keep it that way.
    But there are a few things that I don’t particularly care for. For my 2nd skimmer to be skimming, I need to have the 2nd 1.5HP pump running. I only run the 2nd skimmer about 1.5 hours per day, which works most of the time. Occasionally, I need to run my IFC just to help clean debris off of the water surface, which requires a manual intervention of my pool controls. This is not a complaint; this is just an observation if anybody reading this is considering including IFC in their pool build.
    To clean any dirt from my spa floor, I need to put the pool into “spa mode”, since the spa floor drains don’t suck water in any other operating mode. For me, this is a non-event, since the spa floor never seems to be dirty. I suppose I could re-program the controller to do this differently, but if it ain’t broke….
    My PB provided nozzle removal tools for both sizes that are in my pool. It’s very simple to install and remove the nozzles with this tool, which fastens onto the skimmer/brush pole. Apparantly the nozzles need cleaned on some frequency, but mine haven’t had any issues yet. According to my PB, there is a lifetime warranty on the system, but I think this is limited to the nozzles. I can’t imagine that the rotating manifold is covered forever. But I did open it once, and it has very few part and looks very easy to rebuild.
    At one point, my PB didn’t give me very detailed answers on how the system works. I emailed Paramount customer service, and got a response within a few hours. We carried on an email thread for several iterations over the course of a week. Each response was articulate and responsive to my actual questions. These were not canned answers; the tech was really trying to make sure I got what I needed. Their customer service is frickin’ awesome. It turns out that Paramount only recommends how a system should be installed. PBs can do it however they want. Fortunately for me, it appears that my installation is the way Paramount recommends.
    While researching IFC systems prior to making my commitment, I tended to find only bad reviews online. But most of these seemed to be from people who had purchased a home with a pool with an IFC system and didn’t understand how it worked. (For example, there are many threads out there about people thinking the permanent static pop-ups are broken because they are always up when the pump is running. This is a design feature, not a malfunction.)
    I’m sure that there are pool owners with IFC systems that really do not work as intended, but I am quite happy to say that I am not one of them. If you are building a new pool and have room in your budget, I highly recommend putting one in. You’ll be glad you did.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    jerrypar72's Avatar
    Nov 2007
    Phoenix
    32
    Re: My thoughts after using Paramount PCC2000 In-Floor Cleaning system for 6 months
    I chose the PCC 2000 IFC when we had our pool built 15 years ago. It was the best $2k that I have ever spent!! Our pool stays debris free and clear all the time! Visitors assume that I must spend a lot of time cleaning the pool, but it's actually the opposite! I highly recommend the PCC 2000 to anybody building a new pool!
    11,000 gallon Tahoe blue pebble tec, PCC 2000 in floor cleaning system, with two Pentair 1.7HP cleaning pumps, and a separate pump for water feature, Frog chlorinator, 60 SF DE Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Very good review, thanks!
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Excellent feedback. What size pump is running it?
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by pooldv View Post
    I have a 1.5HP Hayward® Tristar® pump driving the IFC nozzles and an identical pump that drives the filter loop. According to my PB, these are the sizes of pumps that Paramount recommends for my system.
    I asked my PB (and subsequently Paramount customer service) why they don't spec an adequately-sized dual-speed pump instead of 2 separate pumps. They said the pump sizes are specified based on the required water flow through the nozzles. In any single-pump arrangement, the water would have to flow through the filter before going through nozzles. In order to account for increases in pressure drop as the filter gets dirty, they would have to over-size the pump. By keeping the nozzle loop separate from the filter loop, they can employ smaller (i.e. more efficient) pumps in their designs. While this response seems logical, I have never run the calculations to determine if this response is reasonable. At the end of the day, I really don't care. I only run the 2nd pump 1.5 hours per day, so my potential electricity savings is quite small.
    Quote Originally Posted by JayBauman View Post
    Great overview of the paramount in-floor cleaning system. In my personal opinion, if you have your choice between A&A or paramount, I would choose A&A. The engineering and design is superior, in my opinion.
    * A&A uses a single variable speed pump (ie intelliflo) to drive the system. There is no separate filtering loop with returns, the water is always returned through the infloor which allows for better circulation than a standard return loop. The variable speed pump allows you to dial in the exact flow to zero in performance. Every plumbing system has varying hydraulic performance measures, and a single speed pump may not meet the need of every pool.
    * A&A uses venturi skimmers. The skimmers are powered through return flow - each uses 8gpm on the return side to produce 30gpm of equivalent suction from a traditional skimmer. Because there is not active suction on the skimmers, 100% of the suction power is given to the drain.
    * A&A venturi skimmers are always operating, whether the variable speed pump is high or low speed.
    * A&A uses venturi cleaning heads, which require significantly less flow than a traditionally designed cleaning head.
    No, I dont work for A&A, just very interested in the technology and have been comparing the 2 brands for awhile now. That being said, most of the owners I have spoken too with both systems seem to be very happy with the operation of each brands respective latest generation
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
