Results 1 to 8 of 8
Thread: first above groubd pool 16' 48" how unlevel can it be?
    Jun 2015
    wentzville mo
    1
    Question first above groubd pool 16' 48" how unlevel can it be?
    so my wife really wanted a pool this summer for our back yard so for her birthday i got a 16' 48" round above ground. we got it from wal-mart(trust me i tried to talk her out of it). putting together seemed really simple but once i got to filling it i realized how unlevel my yard really is. got it half full and didnt like what i saw so i drained it. it was about eight inches out. took the pool down and moved, and started digging, leveling it with a 2x4 and a level taped to it. i got pretty close, or so i thought. after we filled the next time around, just as it got to about full, i noticed it was still unlevel. it doesnt really seem concerning and we are not going to have any kids horseplaying or kicking off walls or anything like that. mainly so wife and 3 year old can have somewhere to cooldown this summer. but figured it wouldnt hurt to ask some of you whether or not it is concerning, and if it is, is their anyway to fix it without draining? the first pic is the water level at the high side, and the ladder is at the low side. should i be terribly consider or have something to do without draining the pool? my only concern is it bursting, the frame being warped or something like that i really dont mind as long as it lasts this summer.unnamed.jpg3.jpg4.jpg
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Re: first above groubd pool 16' 48" how unlevel can it be?
    A measurement would really help. Look about 2" low?
    You have your terms backwards btw. The low side is the side with the higher waterline. The ground is lower there.
    Generally it is recommended that you be within 1" of level. I doubt it is a huge risk with an additional inch if there is no one kicking off the walls. It is enough to make you worry a bit though.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Orlando, FL
    690
    Well, that story sounds like the lament of every Intex pool owner everywhere. The "gonna get this pool and put it up on Saturday, and swim Saturday afternoon" fantasy rarely comes to fruition. Four weeks later, you fill and say, it's good. Mostly.
    Anywho, you should do all that you can to get it within one inch of being level for safety reasons and your sanity. If you don't get it level, you will never enjoy your time in that pool. Not that I would know...nope. I just overhead some people talking. Lol
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2015
    Fort Pierce, FL
    129
    I am with this same problem now. Draining as we speak to attempt to move it and level some more. I am frustrated because I want it to be perfect. It looks like we have the same exact pool and with proper maintenance and putting it up properly it should last for many years to come. When I get home from work my plan is to try the 2x4 with level trick to see how much more dirt I need to add, would LOVE to only be 1-2 inches off, last night I was about 8-12 inches off!!!
    Intex 16x48" Ultra Frame AG Swimming Pool 5K gal
    intex 2650 sand filter
    May 2015
    Pooler, GA
    311
    Quote Originally Posted by cooljul View Post
    You should never add dirt. You should only take away. Adding dirt just means that it may get washed out a few months after it is setup.
    TF-100
    Helpful Links
    Jun 2015
    Fort Pierce, FL
    129
    Yes kimkat helped me with that one post that I added today. I'm sitting on my porch listening to the water drain so I still have a bit to go before I can attempt to level again, my post is here Should I use cement pavers under Intex legs?
    Hoping for any and all helpful tips!
    Apr 2014
    FOUR cORNERS
    111
    all of us who did the dirt work of leveling can't stress this step enough, take your time and do it right, then you're done with it. PATIENCE is your friend here!!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jun 2015
    kettering
    10
    Level with patience. Also take into account the way your liner attaches to the pool wall. You liner can stretch and you can have if off level but pool within reason. Take the level to your side rails dont eyeball the waterline. When i put my 24fter in i felt i was off as well despite using a buddies survey gear. However if i take a level to it, it levels perfect but just has the appearance due to the liner
