Results 1 to 8 of 8
Thread: Chemical Issues
    Jun 2015
    New England
    2
    Chemical Issues
    Hello,
    I'm having monumental issues getting my pool chemicals balanced this year. Things were good two weeks ago after having added Cyanuric acid, Calcium, Chlorine, and eventually and anti-metal solution to lower the Copper levels. Two days ago the pool started getting algae green but my test strips showed the Chlorine levels as stable. It turns out the test strips were moldy and none of the numbers were accurate. Today, after buying fresh test strips:
    pH = 7.8
    Free Chlorine = 5
    Alkalinity = in the 180 territory
    Stabilizer = between 30 and 50
    I'm not sure of I have an algae bloom or another surge in metals. I've already spent $200+ in chemicals and was hoping for some advice as to what this may be so I can avoid buying way more than I need. Any input is greatly appreciated! Thanks!
    30,431
    Re: Chemical Issues
    Metals do not come out of your water nor are they added to your water (unless you put them in)
    Test strips moldy or new are pretty much worthless and will make it impossible to analyze your pool.
    Have you had the pool water tested for metals?
    Please change your zip code to a city, state so we can judge your climate.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Chemical Issues
    Not good news at all. Green is not a good look on a pool
    There is one more thing you need for you pool--------------a good test kit so you will not be "pool stored" any more. You can find the link to the test kits we use and love in my siggy.
    With a good test kit you can "fix" your pool with stuff from Walmart! Bleach is our main "tool" to fix a pool. If you do have metal in your water it might be a little harder but it is fixable.
    Kim
    Jun 2015
    New England
    2
    Re: Chemical Issues
    Thank you both for the quick replies! I updated my location to a generalized area solely for privacy. I am in New England which should provide an idea of the climate. I've also added an image as a frame of reference (not sure if this will help).
    Jun 2014
    15,212
    Re: Chemical Issues
    Wow. That is classic green, Without a proper test kit, you can only do so much. For now I would suggest:
    #1 -Order a TF-100 or Taylor K2006 (link below). That's priority 1!
    #2 - If you have any kit at all, try to keep PH at 7.2 for now before you "SLAM"
    #3 - Add one gallon of bleach to the pool each day just to keep the status quo.
    #4 - Do NOT use any more products from the pool store, ask for their advice, or testing. Just a waste of your money
    #5 - Read thoroughly the "SLAM" link below. You'll use it when your kit arrives.
    Others may reply as well if I missed anything.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Chemical Issues
    It shows a pool that needs to be SLAMed.
    You are going to need to get a good test kit. We CAN help you get your pool clear. Here are some links to swamp to clear threads.
    Before and after!!
    Let us know when you have your test kit and we can go from there.
    Kim
    Apr 2015
    Quinlan, tx
    811
    Re: Chemical Issues
    Welcome! You can do this! Be sure to follow the advice given and be persistent. You will be glad you did!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Chemical Issues
    That certainly looks like an algae bloom. Algae is really only caused by lack of chlorine. Has your pool spent some time with low or no chlorine recently?
