Thread: Pool Deck - Pavers or Concrete
    I'm paralyzed with moving forward with my pool install because I can't decide which surface material to use for the pool deck (I'm located in northern Illinois)
    Pavers/Unilock-- Pros: can be broken down and reset easily if settling occurs; cons: Sand in the pool. Yes, I've heard of polymeric sand that binds together, but several people who have such sand say that the polymer breaks down over time, still releasing sand which constantly gets in the pool. Several people with pavers have sworn that if they had to do it all over again, they would never get pavers.
    Swept concrete - doesn't look as nice, but easy to replace if it cracks or settles or there's a need to get at the pool plumbing for some reason.
    Stamped concrete - often looks nice, but there's no chance of coming close in terms of color/texture if you have to replace any sections due to cracking or settling in the future.
    Pavers set in concrete - Expensive, but might be the only solution that lets me sleep at night. Great paver look, without risk of sand in the pool.
    How many of you have pavers and love them or hate them?
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Pool Deck - Pavers or Concrete
    I have concrete. To help with settling I ran soaker hoses, on and off for a couple of weeks around the excavted area. Moved many loads of dirt to fill in the step, spa, skimmer area. Around the pool it settled 6" to 8". Probed the soupy mess with a length of 1" pvc to help settling.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Mar 2007
    Ontario
    211
    I have 3' of concrete around the pool, with a swirl brush look. And unilock pavers for the rest
    of the decking area. The prep work is the key to the pavers. I used polymeric sand and love it
    no problems so far. We just finished are 2nd season.
    I went with the paver look because I thought to much concrete would look like a big chunck
    of sidewalk.
    If you would like to see a couple pictures of my deck I have a thread on the 3rd page of
    the "show of your back yard forum". Titled before and after.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Unless your builder knows a good way to meet code for bonding the pavers, go with concrete. If he doesn't understand bonding the concrete, get a new builder.
