Thread: Calculating pool volume
    Jun 2015
    Eastvale, CA
    15
    Hello,
    When calculating volume of a pool with an attached spa do I include the spa or keep them separate. This is for use in the Pool Calculator. I am guessing I include it considering the spillway between the spa and pool. Thanks.
    -Matt
    ~12.5K gal 10'x40' IG pool + attached spa, StoneScapes Mini-Pebble
    IntelliFlo VS (main), WhisperFlo 2HP (spa), SuperFlo 1HP (waterfalls)
    Pentair FNS Plus DE filter 60sq, EasyTouch w/ SWG, Dolphin Z5 Robot
    Mar 2015
    Georgia
    157
    Re: Calculating pool volume
    Since they are both connected to the same body of water then yes add them together if you can. The goal is to have the right amount of gallons of water that you are treating so you get the right dosage amount. Though a spa that is 500 gallons in size probably wont make much difference in the dosage amount with ~14,000 gallons of water.
    16k AG Vinyl Sand Filter
    Jun 2015
    Eastvale, CA
    15
    Great thanks! First pool and not sure how accurate volume needs to be.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Quote Originally Posted by mrweber View Post
    Pay close attention when you're adding chemicals. If you start with, say 15,000 gallons calculated and you consistently overshoot, lower the volume you use in poolmath by 1000. If you come up short, increase it 1000. After a couple weeks, you see things going up or down, fine tune it again. Eventually you will hit a number that consistently gives you the results you expect. Poolmath - and especially Effects of Adding Chemicals down at the bottom of it - is your best friend.
