Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Coping question
    Jan 2015
    Tuttle/Oklahoma
    147
    Coping question
    So I have been researching what the best stone is for pool coping and it appears that most are going with Travertine. However, I have read about a lot of people having problems with it flaking and pitting only a few years in which has me concerned. Apparently it is particularly a problem in Texas, and I am in Oklahoma which is much closer to Texas than I would like
    My only local options seem to be:
    Travertine (from Mexico): Current Leader
    Slate: Love the look but have read it is even worse than Travertine
    Brick: Durable but I'm personally not a fan
    Concrete: Durable but again, just not a fan as we really love the stone look.
    Pavers: Maybe my "safest" option
    I have read that Quartzite is denser and will last much longer but I would have to order this online. However, when I Google "Quartzite pool coping" it doesn’t pull much back which surprised me.
    Just confused and looking for some thoughts or guidance. Will I be alright with Travertine if I seal it every year?
    My Pool Build Thread: 21 x 40 Freeform Gunite Pool, 12" Tanning Ledge, 3.5 shallow graduating to 4.5, 8.5 deep end, 4' Waterfall which doubles as a diving ledge with 6' x 4' Grotto underneath, 670 sq. ft., 106 Linear ft., Rock Salted Concrete Deck, Pentair 520 Filter, Intelli flow 3 HP VS pump, (4) Color LED lights, Intelli-Chlor SWG, Hot Springs Vanguard Hot Tub with ACE and BT Sound System, ODK, TF100
    Jun 2011
    Carlsbad, NM
    172
    Re: Coping question
    Quartzite would be the most durable. Many varieties of flagstone are also durable. The best part about flagstone is the flaking doesn't hurt the appearance.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Re: Coping question
    You've probably already seen this when you searched, but just in case.... Quartzite | National Pool Tile Group
    We have the Travertine coping and will have a salt system. We will seal the coping. I was out sweeping it today - another story.... Anyway, all I could think was how much I love how it looks and how it feels. Sometimes it's just worth livin' on the wild side!
    I also think the Quartzite is beautiful. I have a gorgeous picture of Quartzite on either a beach entry or sun shelf - can't remember. As with other things - I found Quartzite after I had Travertine. I've never touched the Quartzite, so I can't say how the feel compares to Travertine.
    Will the look of pavers work with your pool design and house? Good luck! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jan 2015
    Tuttle/Oklahoma
    147
    Re: Coping question
    Quote Originally Posted by SuzfromTexas View Post
    We have the Travertine coping and will have a salt system. We will seal the coping. I was out sweeping it today - another story.... Anyway, all I could think was how much I love how it looks and how it feels. Sometimes it's just worth a little livin' on the wild side!
    I think we really like the look of stone. Love the clean, rich look of Travertine just worried about the durability.
    May 2015
    Houston TX
    49
    Re: Coping question
    I,too, like the look and feel of Travertine. We like the Tiramisu color. But my pb keeps pushing flagstone ! I want the pool edge to be bullnosed. He says they always bullnose flagstone. Then I've read where flagstone flakes and chips. And when using it for the deck it'll be uneven, making chairs unstable. We do not have a SWP. Our pb also says to use travertine coping we'll have a lot more grout lines and that it won't look good . Another question about travertine coping. Should it be lighter or darker than the decking ?
    Houston,TX, IG 15120 gal, gunite, 22' x 36',wet edge finish, Pentair equip, 420 cartridge filter, vs pump, Intelliflo vs booster pump for water features, 400,000 heater, auto fill ,PCC 2000 in floor cleaning ,2 LED lights,travertine coping, paver decking, 9x12 tanning shelf ,1 LED color bubbler, 2 5' benches w jets. Depth 4- 4 1/2- 5 , wall with 3 24" sheer decent , 2 spray heads, Intellitouch Controller.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Coping question
    Ours deck travertine is the same color as Coping.
    Coping grout lines are typically very narrow for travertine to fall in with the lack of grout lines in the deck.
    This is a factor of how good the tiler is in cutting too.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Sep 2014
    Dove Canyon, CA
    22
    Re: Coping question
    I saw a pool done by one of the builders I'm considering, and the coping and surrounding patio were quartzite. Absolutely gorgeous. (Apparently the owner wasn't trying to keep costs down like many of us.) The PB said it is the hardest stone, and his mason guys went through several blades because of all the cutting that's involved, adding to the price.
    I'm not sure pricewise how quartzite and travertine compare, though.I think he said quartzite was more expensive. Maybe it depends on the supplier and your location.
    Our present patio, we have arizona flagstone borders with pavers. The flagstone chips like crazy - we have it at our front doorstep as well, and just last week found a whole bunch of it flaked off in large pieces
    Still thinking about it in Orange County, CA...
    Jan 2015
    Tuttle/Oklahoma
    147
    Re: Coping question
    Quote Originally Posted by magicruiser View Post
    I'm no expert but I think the coloring is personal preference. We want a contrast between the coping and the decking and prefer to have a darker coping and a lighter decking in an effort to keep the deck cooler. Unfortunately we can't find a Travertine dark enough for our taste (yet anyway) so it looks like we are going to go darker on the colored concrete deck. I love the look of slate coping as I really like a lot of color an character in the coping but I have not been able to find that in Travertine or Quartzite yet. I too am scared to use flagstone, slate, sandstone, and limestone for fear of flaking. I'm scared of Travertine as well... just a little less... I think...
    Apr 2015
    Houston, Texas
    3,217
    Re: Coping question
    Magicruiser: It could be cost factors your PB is considering. I had a flagstone patio (no pool, did not seal it) for about 14 years. It faded, mildewed, and flaked. It was so beautiful when it was first in. We power washed and tried to remove the mildew. We probably didn't do the right things, and the flagstone may have been poor quality. Due to drainage and accessibility for all the work crews, it had to be removed. I was glad. It really left a bad feeling for me about flagstone, so I admit to being biased. And ours was uneven with the chairs, but I can't say that bothered us too much.
    As far as colors for the coping and decking, that's definitely personal preference - style and function. As soon as PB's and landscapers saw my canes, they encouraged me to go with a contrast between coping and decking. I didn't see how my mobility issues would be helped with the contrast - my eyes are still workin'!!! LOL!!! But I guess as I get older and older (God willing), the contrast will get my attention better. I'm now getting Travertine decking in a shade darker than the coping. If I had started with a darker coping, I would have chosen a shade lighter for the deck.
    Here's a couple of pictures of my coping around the pool and the bump-out bench. I can't say I even notice the grout lines when I'm outside looking at it. I guess I don't think about the grout lines - they're no different than the grout lines I have on tile flooring or in the shower. I guess I just expect it, so I don't notice it. All these decisions...... Good luck! Suz.
    I don't have a great photo of the entire pool with grouted coping (there's too much glare). So this one shows the coping behind the sun shelf. If you look at the top right of the picture, you'll see the grout lines. For me, that would be the worst of it.
    This is a photo of the Travertine on the bump-out bench. It shows the coping and then the Travertine on the seat of the bench. The grout lines definitely show, but I don't see the problem your PB is talking about. Sorry, but when it's blown up, it's blurry.
    Jun 2015
    Phoenix, AZ
    216
    Re: Coping question
    @SuzfromTexas What are the multi color 'triangle' tiles that you have on the step? Is it something that I can purchase separately and ask my tile guy to lay it? I wonder where I can get these at a lower cost?
    Apr 2015
    Houston, Texas
    3,217
    Re: Coping question
    Quote Originally Posted by trbvm View Post
    Welcome to TFP!! They are called Shell Beach made by * Lightstreams Glass Tile | Exquisite Glass Tile Manufactured in the USA Home Page. I have pictures of the samples I bought on my pool build thread - click on the link in my signature. Their website is fabulous. I'm not aware of any place to purchase them for less. If you have more questions, I can answer them on my thread. Take care! Suz.
    May 2015
    Houston TX
    49
    Re: Coping question
    Suz, thanks for the pictures ! First, I love your shell beach ! And your bump out bench is a great idea. You are so thoughtful for all the help you give us newbies ! I have read many of your comments and not only have I learned a lot but have been entertained with your great wit ! As a Texan, I'm sure you understand the frustration from all the rain !! They were suppose to dig Sat. But it didn't happen ! Now more rain is forecast for the next week !! So it's really helped my morale to read these posts !! I think your travertine coping is pretty ! And I'm perfectly fine with the grout lines. I am not going with flagstone. I just don't like it. And like you've said, "it's your pool " ! LOL
    Jun 2015
    Phoenix, AZ
    216
    Re: Coping question
    Thanks Suz. I will continue on your build thread with a couple of questions on these tiles
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Jun 2015
    Duncan, OK
    17
    Re: Coping question
    Soonerwing what did you end up join with? We are looking at doing a contrasting color with travertine coping and stained concrete decking. Do you have any pics?
    New build, vinyl IG 18x40 3'4-9'
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Coping question
    Slate and travertine are both types of flagstone with varying hardness levels. I love travertine and I would put it in if I could, but the bluestone flagstone I am going to use can withstand our freezing weather cycles.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Re: Coping question
    Quote Originally Posted by Helen203 View Post
    An Engineer and Geologist!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2015
    Long Island City, NY
    70
    Re: Coping question
    I've heard diametrically opposed opinions on travertine in freeze/thaw areas. Some claim it will be destroyed in a few seasons. Others claim they have installed thousands of feet using a dry cement/sand mix over concrete slab. Do you have any experience with travertine?
    I also considered limestone. Local supply yard refuses to sell limestone pavers due to cracking as a result of freeze thaw cycle. Doesn't make sense, half of New York City is covered in limestone steps, coping, sills, bridge cladding, etc...
    Confused in NYC
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Coping question
    Quote Originally Posted by vermaraj View Post
    Confused in NYC
    I am not a geologist, haha, bmore was just teasing. But I do know that travertine is very porous and water + freeze-thaw could be a bad combination, right? Marble and limestone are too soft. Granite is frequently used on public buildings around here. We do have slabs of sandstone slabs for our front steps. 54 years old later (house is older than me!), we have moderate erosion.
    Sep 2015
    Arkansas
    9
    Re: Coping question
    Iv built over 500 pools In my life and true cantilever coping is hard to beat if done right. The grout in the stone will crack the rocks will flake off eventually. Pour stamped and colored coping and have your builder every 5 feet around the pool run rebar out and then pour you deck and tie the two together can't beat it
  20. Back To Top    #20
    Sep 2015
    Arkansas
    9
    Re: Coping question
