Thread: Skimmer suction question
    May 2015
    TN
    312
    I don't think my skimmers are doing the job they are capable of. I have a lot of debris/bugs on the surface of the water. The skimmer in the shallow end is suctioning well and skimming well it seems. There is lots of water movement inside the box. However, in the deep end skimmer the water is barely moving inside there and not near as much suction. Anything sound abnormal? Can I do anything to help. My water level is at the little arrows on the skimmer.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    30,419
    Re: Skimmer suction question
    Do you have one of these in the bottom of the skimmer that's doing well?Skimmer equalizer.jpg
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I've had the skimmer farther away from the pump seem to not work as well. I put my hand over the hole in the nearer skimmer to force more water flow through the other one and it seems to get things moving better again. Air, leaf, I don't know. Has only happened a couple of times.
