Thread: Loosing water very fast
    Jun 2015
    Staten Island, NY
    1
    Hello everyone,
    Last weekend I opened up my in ground pool. Since then the water level dropped significantly. Here is the sequence of events.
    Last Saturday I put water pump on the turpentine cover to remove water from it. The water level was about one feet from the ground level. Pump run for about 2 hours then it started to rain, so I shut off the pump and went inside. It rained all night. However, in the morning I was surprised to see that all water is gone from the cover and the level dropped to about two feet from the ground level. At first I thought, eh... no big deal, probably "communicating vessels", as it looked like the other end of the hose was lower then the pump on the turp. Then I removed the cover, started water pump, dumped 18 gallons of chlorine in the pool, connected leaf bagger and started collecting leafs. After I was done with the leafs, I left water hose running to full up the pool.
    On Monday, I noticed water level dropped because skimmer was making noise by sucking the air. I refilled the pool with water and had water pump off over night.
    Here is a picture I took Tuesday morning.
    This is how it looks today.
    Also note wrinkles, it didn't look anything like that when I pulled off the cover.
    I was suspecting plumbing, but as the water level dropped below the return jets doesn't seem to be the case. I can't see any obvious damage to the lining.
    TF-100 kit says chemistry looks as follows:
    CL <.5
    pH 7.3 - 7.5
    TA: 50
    CH: 40
    Please advise.
    Jun 2015
    Wildomar, California
    423
    Re: Loosing water very fast
    The fast way to diagnose a pool leak is a bucket test. It's pretty foolproof. Turn everything off. Mark the water level in the pool. Find a large bucket, no leaks, fill and mark it's water level Use a large bucket like a 25lb 3" tab bucket. Wait 24 hours and compare water levels. If the pool level is less than the bucket, you have a leak. Of course, rain, or a dog drinking from the bucket would dis the test.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    you really put in 18 gallons of chlorine at once? seems like too much, whats your pool volume?
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Apr 2014
    Stony Brook, NY
    159
    Wow! That's a lot of water to lose. You have a serious hole somewhere. Maybe main drain.
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    30,419
    That's a pretty robust leak. I would continue to let it drain to see where it stops. If it is still leaking when there is only 6-8 inches in the shallow end, I would start to refill so your pool doesn't get too low and call a leak detection guy if you don't finds it by then.
