Thread: Dry Acid vs Muriatic Acid
    May 2015
    river vale nj
    6
    Hello,
    I really want to continue to follow the TFP/ BBB method as it has been giving me stellar results since I opened for this swim season. My question is what are the disadvantages of using dry acid over Muriatic Acid? Prior to joining the TFP website I purchased a 30 lbs. bucket of pH minus (sodium bisulfite I think?). I was just wondering if it is all that bad to use versus muriatic acid since I dropped $59 bucks on the stuff....I promise not to buy it again!
    FC 7
    TA 100
    CC 0
    CYA 75
    pH 7.6
    30k gal vinyl IG, 24 sqft Hayward DE filter, 1.5 HP Hayward single speed pump, Raytec gas heater, Polaris 280, Taylor 2006 test kit, bleach 8.25%
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Dry Acid vs Muriatic Acid
    It adds Sulfates to the water. Long term use can lead to Crystals forming, but it wouldn't be the end of the world to use up what you have.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    It's not bad to use occasionally, but using it will build up sulfates in your pool. This can be bad for concrete surfaces, tiling and other pool related surfaces. Read a synopsis here and you can download the full .pdf. Sulphate attack |
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Since you've got it, use it. There are a lot of threads about it if you try the search box. Here's a recent one Acid - Dry or Liquid?
    May 2015
    river vale nj
    6
    Thanks so much!!!
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Quote Originally Posted by JVTrain View Post
    My understanding is it can also damage a SWCG cell.
    I know the OP isn't using one, but I just wanted to put that out there for anyone else reading this thread who may be using a SWCG.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
