Thread: CC test
    alexteek's Avatar
    Jun 2015
    Schertz, TX
    17
    CC test
    I have a TF-100 test kit. When I finished my FC test (7.5 today with a CYA of 50), I put in the 5 drops of R-0003 and it does not change color for about a minute. After a minute there is the slightest tinge of pink. I put in my one drop of R-0871 and it goes clear. Am I doing this right?
    Ann
    7.5 pH
    7.5 FC
    0.5 CC ?
    50 CYA
    275 CH
    80 TA
    Finishing SLAM from last week.
    Pool is clear and brilliant!
    alexteek
    16x32' 13K, IG Tan Fiberglass, 1HP Superflo Pentair pump, Pentair 150 sq. ft. Cartridge, Polaris 360, Built November, 2014
    30,421
    Re: CC test
    The solution should change back to pink just as soon as you put in the 5 drops of R-0003. That it did not indicates you have no CC's.
    Ignore that return to pink after a minute.....it's not relevant to either test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: CC test
    If it didn't go pink right away after adding the R-003, you have zero CC.
    The FAS-DPD test turns pink again if it sits too long. Ignore it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CC test
    The chlorine tests should be done as quickly as possible. In either case of FC or CC testing, if you let the clear solution sit for more than few seconds, it will turn back to pink. If it stays clear immediately after adding and mixing the R-0003 you have 0 CC.
    Isolated Spa - 345 Gallons
    Jun 2014
    15,174
    Re: CC test
    Yeah! That's a good thing. No CC's!
    alexteek's Avatar
    Jun 2015
    Schertz, TX
    17
    Re: CC test
    Quote Originally Posted by Texas Splash View Post
    Thanks all!
    The last response is important too - I thought I had to figure out how to get it to .5 CC
    Ready to swim again!! I have saved so much money this time. THANK YOU!
    Ann
    alexteek
