Thread: Ladder question (above ground)
    May 2015
    Savannah, GA
    62
    Is it common for an above ground ladder to wear a groove in the bottom?? We're thinking attaching it to a deck landing might help it stay more solid and stable. Right now it's just freely sitting over edge. We tried to level ground outside pool best we can but it still moves a bit when people climb up and over.
    Suggestions please to help our issue.
    24 ft round 52 in deep Evolution CLX 13,000 gal, hayward S180T sand filter & 1 hp Power-flo Matrix single spd, TFP method BBB, taylor K-2006 kit
    24 ft round 52 in Evolution CLX 13,000 gal, Hayward S180T pump sand filter & 1 hp Power-flo Matrix single spd, TFP method, Borates Added, Taylor K-2006 Test Kit (Rincon/Savannah,GA)
    Orlando, FL
    690
    Re: Ladder question (above ground)
    I have not had this happen and I do keep a rubber mat under my ladders to protect the liner. The pool has been up for over a year and no groove has appeared under the original ladder. The ladders do move a bit but no issues.
    There are many ways to add weight to the ladder such as water or sand inside the ladder (if that is how it is designed), added concrete to bleach bottles or pvc pipe and securing them behind the stairs. I had a weight set in the closet that was not being used so, I put a 10 lb weigh on the stair platform and a brick covered in a soft material on the bottom step. It made a world of difference.
    Search the forum and you will find many threads. I am also sure others will come along and provide details of how they have stopped/minimized ladder movement.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    DaneCE's Avatar
    Jul 2011
    VA
    279
    My ladder has created small concave impressions. I'm not worried about it. I did sandpaper the plastic that meets the vinyl super-smooth. Just an hour ago I was inspecting my liner underwater and I saw no issues. My ladder is mounted to my deck but that doesn't reduce the weight of the user very much.
    Using a mat sounds like a good idea especially if the ladder tends to walk around. Mine is filled with pool water and doesn't move much.
    Jul 2014
    Oakbank, Canada
    389
    I used a 3/8" rubber mat under mine to stop the legs from depressing the liner and making "grooves".
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
