Results 1 to 7 of 7
Thread: The right Test kit?
    Jun 2015
    SAN MARCOS, TX
    2
    The right Test kit?
    I just purchased a K-2006 Complete FAS-DPD chlorine test kit. That was before I found this web site, which suggests the T-100. Have I made a mistake? I am looking for a kit to monitor my CYA levels. I have a 24 ft diameter above-ground vinyl pool. .
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: The right Test kit?
    That kit will work fine. In fact, it's what many (if not most) pool service professionals use. The major advantage of the T-100 is that it provides more of the reagents most commonly used, so it generally a much better value for the residential pool owner.
    chiefwej
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    Nope, it'll work. It has the same reagents as the TF100, just smaller quantities, hence, lower price. Side by side comparison in Pool School - Test Kits Compared
    Jun 2014
    15,221
    Hello John! I'm right down the road from you. Welcome to TFP. You're in the right place for rock-solid advice. Have a nice weekend.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Yep, the K2006 will serve you well.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    38,470
    Side conversation that had no value added was moved HERE.
    Jun 2015
    SAN MARCOS, TX
    2
    Thanks for the information.
    JB
