Results 1 to 10 of 10
Thread: SLAM Pool at this point?
    May 2015
    Rowland Heights, CA
    6
    I read another thread that the pool should be SLAMed after a full drain.
    I did a full drain in April under that advice of the pool store due to high calcium hardness. At that point, I didn't know of this forum so I filled the pool with the chemicals they recommended me: Instant Pool Conditioner, Scale Free, PhosFree, Muratic Acid, Powder Plus and Pucks (which I no longer use other than Liquid Chlorine)...
    Found this forum last month and switched to The TFPC method.
    However, I've never SLAMed my pool after the water change. Only "shocked" the pool 2 or 3 times using Powder Plus prior to finding this forum.
    My CC is almost always at 0 and never exceeded 0.5 and water looks super clear. So clear that you cannot see the water on a calm night.
    Since last month, after finding this site, I've been keeping it balanced as so:
    FC 5-7
    CC 0-0.5
    pH 7.5 - 7.8
    CYA 50
    CH 280
    TA 100
    So, at this point, should I still SLAM my pool? I lose about 1 ppm of FC daily with the solar cover on.
    Thanks!
    18,000 gallon, plaster, DE filter, 2HP Hayward, 1 skimmer, 1 Pookskim (that works better than the actual skimmer), 1 main drain, 2 returns, manual chlorination, Blue solar cover. K-2006. Southern California (Los Angeles)
    38,298
    Re: SLAM Pool at this point?
    We never "shock" our pools for no reason.
    The SLAM process is used only if there is a problem ... and from what you wrote, sure does not sound like you have a problem
    You can always do the OCLT to see if there is anything in the water consuming your FC that would warrant the SLAM process.
    30,421
    Since you are already only losing 1 ppm daily, the OCLT is a moot point. There is no need to SLAM the pool. You already meet the three criteria that ends the SLAM.
    1. Your pool water is sparkling and there is no visible algae
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    Very nice work in managing your pool. You likely will not need to SLAM or "shock" the entire swim season.
    May 2015
    Rowland Heights, CA
    6
    Thanks jblizzle & duraleigh! I guess I'm fine then
    Also want to comment on how well this TFPC method is working for me.
    Water is much clearer after switching to this method.
    In addition, I have sensitive skin, when I swam in the pool with the many chemicals that the pool store recommended, I had irritation on the skin (same when I swim in other pools). Now, after switching to the TFPC method and swimming in the pool a few times, I've never gotten any skin irritation (even with a FC level of 7, which would probably freak out the pool store people).
    This a a great community and thank you for all the help from the members and moderators! I've joined forums of all types in the past, and by far, this is the most informational!
    May 2015
    Rowland Heights, CA
    6
    Just noticed that you are the site owner from your signature duraleigh, forgot to thank the site owner as well in my previous post. Thank you for creating such a wonder platform for pool owners around the world!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Welcome!
    Looks like you timed things just right. No way you'd be able to drain and refill now.
    Pretty good racket the pool store has, isn't it? Load your pool up with snakeoils, drive CYA through the roof with pucks, raise the already high CH with CAl-hypo shock powder, and then tell you to drain it and start all over! That prominent national chain should rebrand themselves as BOHICA pool supply.
    May 2015
    Rowland Heights, CA
    6
    Haha that's right Richard320, perhaps Pool Stores are one of the causes for the drought here in California .
    I felt so bad about draining the pool amidst the drought. Now reading the threads here, I almost feel that I didn't need to drain it.
    I checked with my water district a few times before doing the drain and they were so easy going with it. My bill only went up $60 to fill the pool back up, I have a feeling that water districts are not doing enough to promote water conservation. But they're not to blame...I'm the one who used up 18K gallons of water...
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Welcome!
    Ok, I have to ask, what does BOHICA stand for? You can PM me if it isn't suitable for public display...lol.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by Saturn94 View Post
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    LOL! So true!
