Thread: how many GPM is my pump its a UST1102
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: how many GPM is my pump its a UST1102
    Unfortunately, that's a motor number, not a pump number.
    And GPM can vary with what size impeller, how long the pipes are, how high above the water the pump is, even how big the pipes are.
    Are you trying to figure out turnover time? Don't bother. Follow these instructions: Pool School - Determine Pump Run Time
