Thread: Problems with Intex 2500 gph pump taking in air
    Jun 2015
    Bristol/CT
    1
    So I had a 16' x 48' Ultra Frame last year. Used the 2500 with it & had no problems at all. I upgraded to an 18' x 48' this year & if I hook up the wall mount skimmer or attach the vacuum to the strainer, the pump starts taking in air. Anyone else have this issue?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Problems with Intex 2500 gph pump taking in air
    Welcome to TFP! If you don't have the hoses completely filled with water prior to start up, you will get air.
    If it is a fe bubble of air let it run a couple mins, turn it off and release the air from air release valve if they have not gone away.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
