Anyone have wiring instructions for a pool light and spa light on a AQL-PS-4? Found the instructions on wiring a 2 speed pump. Very helpful.
How many "accessories" can be wired to this 4 relay system? I have a blower(AUX 2), pool light(LIGHT), spa light(LIGHT) and 2 speed pump(MAIN & AUX 1). I think because the blower and low speed are using AUX1/2, do I have to add both pool light and spa light to the same (LIGHT) relay? No big deal if both lights come on/off at the same time.
I have a AQL-PS-4 and I have added a 2-speed pump. I added low speed wiring to AUX1. 2 speed pumps works fine. AUX1 was were my spa lights were located. Moved the wire to (LIGHT) Now my GFI shorts out everything when I power on my top left relay. (Main breaker also had to be reset) I have replaced the GFI and the same thing happens. When I disconnect all the wiring to the GFI (2 white 2 blue), the system doesn't short out but the lights do not work because they are wired to the GFI per city code.
