Thread: Hayward AQL-PS-4 wiring help
    Jun 2015
    AZ
    1
    Unhappy Hayward AQL-PS-4 wiring help
    Anyone have wiring instructions for a pool light and spa light on a AQL-PS-4? Found the instructions on wiring a 2 speed pump. Very helpful.
    How many "accessories" can be wired to this 4 relay system? I have a blower(AUX 2), pool light(LIGHT), spa light(LIGHT) and 2 speed pump(MAIN & AUX 1). I think because the blower and low speed are using AUX1/2, do I have to add both pool light and spa light to the same (LIGHT) relay? No big deal if both lights come on/off at the same time.
    I have a AQL-PS-4 and I have added a 2-speed pump. I added low speed wiring to AUX1. 2 speed pumps works fine. AUX1 was were my spa lights were located. Moved the wire to (LIGHT) Now my GFI shorts out everything when I power on my top left relay. (Main breaker also had to be reset) I have replaced the GFI and the same thing happens. When I disconnect all the wiring to the GFI (2 white 2 blue), the system doesn't short out but the lights do not work because they are wired to the GFI per city code.
    Jun 2012
    western NY
    1,559
    Re: Hayward AQL-PS-4 wiring help
    Quote Originally Posted by Sparky1987 View Post
    I am not sure what you mean by this.
    Can you post up some info on the voltages your equipment uses? Pumps may be 240 or 120. Maybe a picture of what you have wired currently.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    22,544
    You only have 4 relays so not counting valves, you can only have four accessories. However since you have a 2-speed pump you only have 2 open relays and since the blower is hooked to one of those that leaves you only one to connect the lights to.
    If powering on the high speed of the pump throws the main breaker then you either have a shorted motor, wiring or have the relay wired wrong.
    Can you post a pic of the wiring in the panel?
