Thread: Light didn't turn on (but then did)?
    MugZona's Avatar
    Jun 2014
    60
    Hi everyone,
    Tonight I tried to turn my pool light on as I always do when adding chemicals. I flipped the switch, but nothing happened. I waited a few minutes (and in that time I also turned the pump on). I flipped the light switch on again, and this time the light turned on just fine.
    I replaced the bulb a few weeks ago, and the light has been working fine since then (and worked fine for as long as I can remember on the previous bulb until it blew). The GFCI works, and I don't think I see any water in the housing (although i don't know how exactly I'd check that for sure).
    Any ideas as to why that light might not have turned on the first time? What things should I check?
    Thanks for any ideas.
    Matt
    13,000 Gallon IG Double Roman End with Steps PebbleTec Seafoam Green Pentair Clean & Clear Plus Cartridge Filter 320 1 HP Sta-rite pump (MPR6E-147L) TF-100 test kit Kreepy Krauly Cacuum
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Light didn't turn on (but then did)?
    My first guess would be corrosion in the switch contacts, this would be my guess if you have a traditional pool bulb, if it is one of the smart LED pool lights then it could be a number of things.
    Jun 2012
    western NY
    1,559
    Bad switch. Is this a standard light switch or is it something built into a control panel?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    MugZona's Avatar
    Jun 2014
    60
    Thanks to both of you. It's a standard light switch.
