Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: New owner, battle weary, what to do next?
    Jun 2015
    Boise, ID
    24
    Question New owner, battle weary, what to do next?
    Opened April 14th by pool store and noted multiport valve was leaking told needed new filter system (45 sqft DE). I tried replacement of spider gasket and several washers and rings that were missing or deteriorated from Americana multiport valve to no avail.
    By time of installation of new filter system by third party contractor with home warranty in late May algae had taken over pool.
    Pool store that "opened" said phosphates were high:
    "Do water change and run filter over weekend then bring back water sample."
    Noted low to zero cyuranic acid (using guess strips).
    Saturday, June 6th did 50% water change, vacumed to waste, added 3lbs. dichlor over weekend thru Monday. Possibly up to 20 ppm Free Chlorine.
    Learned how to prime pump, unclog pump and backwash filter.
    On Monday, I tried 1 scoop of DE to +1psi but clogged filter in one hour due to foggy water.
    Tuesday, pool store was impressed with new water sample FC at 3ppm using store guess strips. Still foggy water blue green. Told to "Keep it up."
    Lowered pH with ~48 oz. Sodium Bisulfate. Still cloudy but looking better.
    Wednesday 20150610
    Evening (Test Kit arrives)
    7.0 pH
    +2 drops 7.2
    +4 7.4
    +6 7.6
    8.5ppm free chlorine (fc)
    .6ppm captured chlorine(cc)
    50ppm cyuranic acid (cya)
    130ppm total alkalinity(ta)
    160ppm calcium hardness(ch)
    Thursday 20150611
    Morning
    7fc
    +1lb Baking Soda
    Evening
    water level had dropped by more than 1/2 inch?
    vacuumed to waste
    added water
    4fc
    1cc
    7.2pH
    +2x60 oz laundry bleach
    6.5fc
    +1x120 oz clorox
    14fc
    +1x120 oz clorox
    23.5fc
    0.5cc
    Pool still foggy but getting better.
    Have not seen drain since April.
    Filter running nonstop since Saturday.
    Have trichlor dispenser and bucket o'pucks (currently out of pool for overnight fc loss) about 3lbs left of dichlor but plan to stick to clorox for now.
    What should I do next? Keep it at 20ppm fc with bleach till it's clear?
    Please help. Thank you in advance.
    20,000 gallons, in ground, plaster, sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New owner, battle weary, what to do next?
    Ok, Keep following the SLAM process Pool School - SLAM - Shock Level And Maintain until you meet all 3 factors
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    It sounds like you bought the Taylor K-2006 kit, if so go ahead and order more FAS-DPD test reagents (particularly 870 powder and 871 titrating reagent, they don't give you enough if you are having to do a SLAM, so it is better to get more than to run out before the pool is clear. (you can get the refills from tftestkits, see my signature for the link, or quick link to XL option 870+871 in larger 2 oz bottle TFTestkits.net )
    best of luck and hang in there
    Ike
    Jun 2014
    15,233
    Stay patient! Stick with the liquid bleach ONLY for your chlorine level (FC) and "Maintain" that SLAM FC. That's extremely important. As Ike already mentioned, keep this going until you pass the 3 items above. It's tedious and a lot of babysitting, but you can do it. Oh, and don't feel pressured to buy just Clorox bleach. Any generic brand on sale will work as long as its active ingredient is the same - Sodium Hypochlorite. It will be something like 8.25%, 10%, or maybe even 12% at some places.
    Also, while you are in the middle of the SLAM, don't worry about testing your PH or trying to change it. It provides inaccurate readings during the high FC levels. Good luck!
    May 2015
    River Falls, WI
    124
    Just keep it up. You're on the right path. All you need is time for the filter and bleach to do the work. Keep up the brushing and vacuuming as much as you can will help too. If you have a lot of floaters and such a skimmer sock could help a little.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Jun 2015
    Boise, ID
    24
    Thanks to all.
    Here are numbers for today:
    Friday
    Morning
    18fc
    0.5cc
    Added trichlor dispenser
    Evening
    10fc
    0.5cc
    0.5'' water loss in 8 hours.
    +128 oz 12.5% bleach
    16fc
    20fc
    vacuumed to waste
    removed trichlor dispenser for overnight test
    cya test < 30ppm?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Is the CYA test cloudy at all? Does the dot stay visible? Did you add 30ppm CYA? Less than a week ago? Is this your first OCLT?
    Jun 2015
    Boise, ID
    24
    Quote Originally Posted by pooldv View Post
    Re: CYA test, last time I tested it it was 50ppm(two independent tests). This time I could see the dot all the way up on the K-2006 test(x2). I thought the new result might be due to the high chlorine?
    I was worried that the trichlor pucks might be adding to the 50ppm so I wanted to retest it, but didn't expect it to go down! Will retest and post results tomorrow.
    This will be my third OCLT. First one was 1.5ppm loss and second was 5.5ppm?! I ordered the XL kit. Thanks!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Good morning, fergusonmi.
    I was wondering about your cya reading and the pucks use too You did say you vacuumed to waste, which would rmove the same percentage as water removed.
    Cya can take a week to show up in tests, so I'd hazard a guess that between the dichlor and th pucks, you're likely still in the neighborhood of your original reading. Normally, you wouldn't test cya during a slam. -- only FC -- so I'm not sure if high FC interferes with the test.
    That's one of the reasons we avoid pucks except for vaca, etc. -- Cya becomes a moving target and the cya level determines your normal FC target and slam FC target.
    I do know that lighting conditions make a big difference -- so here's a video you can check out: Testing Cyanuric Acid with the TF-100 - YouTube
    Lastly, since its the weekend, I just want to add that if you frequently test and maintain your FC at 20, then you will likely make much faster progress.
    Those drops in FC you reported during the week, eg. Down to 10, mean that for more than half the time you were gone you were lower than the "kill zone" which allows the algae to outpace you...so one step toward, then a step back
    So today, if say you dose to 22 ppm at 9 and then check at 10:30 or 11 to see how much you've lost, then bring it back up to just slightly over the slam number again...you will reduce or eliminate the algae's chance to grow back. Then you will also find that your intervals of loss start to reduce dramatically, and by the work week, it may start to hold better.
    You just don't want to go overboard on the "overdosing" -- so frequency is your friend But you also don't want to lose the ground your gaining either.
    Hope that helps.
    Cheers to clear!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2015
    Boise, ID
    24
    Saturday Morning
    15fc
    0cc
    50cya(ok great )
    +128 oz 12.5% bleach (should bring to 20fc)
    lost 1/2'' water (this is all between vacuuming, i vacuum and then add back)
    fc should drop by 10 in a full day of sun, maybe add another 128 oz 12.5% now? Add pucks? Or wait?
    Thanks to all.
    30,431
    Keep the pucks out of your pool....permanently (at least for now)
    Forget your CYA from this point....it is unrelated to the SLAM now that it is in there.
    Now, stay with the SLAM. Brushing often vacuuming as needed and keeping your FC at 20 ppm every time you test.
    What does your water look like now? got a pic?
    Jun 2015
    Boise, ID
    24
    Got it. Thank you. I think I can see the drain! (pictures taken after vacuuming).
    ( I can't take credit for the arwork but I can't say I mind it. )
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Keep it up. The more often you test and adjust back to shock level the faster this whole thing goes.
    Brush at least once a day and remember the nooks and crannies, they hide algae. I can't see below those ladder railings but if there are steps remember the bottoms, or little toe indentations in the side of the pool remember them.
    Test
    Adjust FC
    Test
    Adjust FC
    Brush
    Repeat....
    Support the site
    Jun 2015
    Boise, ID
    24
    Tested 14fc
    +2x128 12.5 bleach
    Brushed edges
    Removed ladder
    Going bleach shopping.
    (1 bottle left)
    Thanks!
    Jun 2015
    Boise, ID
    24
    Tested 14fc
    +128oz 12.5% bleach
    +2x96oz smelly dollar store bleach of unknown concentration
    Brushed sides and turned on bottom drain(oops).
    It's looking good but that's how I was fooled before.
    Jun 2015
    Boise, ID
    24
    Tested 19fc
    +96oz $ bleach
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Quote Originally Posted by fergusonml View Post
    Tested 14fc
    +128oz 12.5% bleach
    Why is the bottom drain an oops? If it feeds the filter, keep it on! Algae could be lurking down inside the drain housing below the cover. You want some bleach water circulating. Anything you can do to improve circulation through the pool helps.
    Jun 2015
    Boise, ID
    24
    Tested 17fc
    +2x96 $ bleach
    When I was vacuuming to waste I turned it off and forgot to turn it back on.
    Shopping for more bleach.
    Jun 2015
    Boise, ID
    24
    Tested 18fc
    +121 oz 8.25% Clorox
    As predicted I've tested myself into a corner.
    Not enough reagent left to do OCLT.
    Added Clorox should bring me to 22ppm fc
    I'll assume a 5ppm loss overnight.
    Add +121 oz 8.25 tomorrow morning and assume a 10-15ppm loss Sunday adding bleach to compensate.
    On Monday I can go by the Pool store to see what they have test wise while I wait for my XL kit.
    I have to say the pool is looking good. Any advice or critique would be appreciated.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Most likely the pool store won't have anything you can use to test over 5
    Just an FYI, you really don't need to worry about an OCLT until your water is clear. The OCLT is one of the 3 criteria to tell you that you're finished with your SLAM but you know you're not done if your water is still cloudy so no need to specifically test for OCLT. Only normal dose and test.
    You'll probably have to go by your "history" to try to guestimate your dosing until you get your refills. Unfortunately it may mean a little stall in your SLAM but you'll still kick that algae out for good in the end!!
    Hopefully your XL will arrive quickly!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
  20. Back To Top    #20
    Jun 2015
    Boise, ID
    24
