Thread: Inspected salt cell - water wouldn't stop flowing
    Feb 2015
    North Alabama
    58
    I decided to inspect my salt cell when the inspect light came on. My understanding is that it comes on after a certain number of hours. This is my first season owning the pool, and I am not sure when the previous owner inspected/cleaned it. When I loosened the rings and took the cell out, water would not stop flowing. The pump was off and the filter was set to "closed". The cell looked fine (although I was in a bit of a panic not knowing what to do about all the water spewing out) and I eventually got it secured back between the two rings despite the water flow. What did I do wrong?
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    38,274
    Re: Inspected salt cell - water wouldn't stop flowing
    Is the SWG below the pool water level?
    Feb 2015
    North Alabama
    58
    The pump system is in another part of the yard...so it's a little hard to tell. But the salt cell is only about an inch off the ground. So it's possible that it's below the water level of the pool.
    Polaris 280
    TF-100 test kit
    Jun 2011
    Long Beach, CA
    2,784
    It sounds like you need to raise it or add a check valve to the plumbing.
    38,274
    Or add some shutoff valves between the equipment and the pool.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    If it is a soft line, simply raising the line above the water level will stop it from siphoning.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
