Results 1 to 12 of 12
Thread: Intex SWG code 91 after cleaning
    Jun 2015
    Portland, OR
    4
    Ok, I'm sure this has been answered before. I've read through the forums on this code quite a bit and nothing has worked yet...
    I have model 8111 SWG with the 16' x 4' pool. The setup is starting it's 3rd year now.
    After dumping salt in it several times it was still reading low salt. Off to the store to buy some test strips. Salt showed almost 5000ppm, so as I suspected, it had way too much salt, but still reading low salt. I disassembled the filter, capped the one end of the clear tube by the copper and filled it with white vinegar as I had seen on many posts here. Let it sit for 3+ hours, the plates looked clean, so I dumped the vinegar, rinsed out with the hose, and reassembled. Still reads low salt. Disassembled again and let soak in vinegar for about 18 hours. Still reads code 91.
    As already mentioned, salt shows about 5000ppm, here are the rest of the readings:
    Total Hardness: 0
    Free Chlorine: 0
    PH: 6.8
    Total Alk: 40
    CYA: 0
    Please help! Am I getting a low salt error due to the other readings being off? Is my SWG dead?
    Thanks!
    Matt
    22,553
    Re: Intex SWG code 91 after cleaning
    I'd have to say that the cell is dead. Since it's 3 years old I'd say it's at the end of it's life.
    While you're deciding on a replacement, it'd be a good idea to read about the ABC's of pool chemistry in Pool School.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! Your cell could be going if it is on its 3rd year. You also want to drain some water and replace it to bring the salt level down to recommended levels. It may correct itself after salt levels are lowered.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    I have to replace my cell every 2-3 years. The same thing happens, 91 with plenty of salt. You can get a replacement on the Intex website for $68 plus shipping. Although you can get the entire unit on sale right now at Wal Mart for $99.
    Walmart: Intex Krystal Clear Saltwater System 7,000 Gallon
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    Portland, OR
    4
    Since I've got the combo pump/filter/SWG, if I replace it what would you guys recommend? I'm thinking if I'm going to drop a hundred bucks or so I might go ahead and upgrade to a sand filter too so I don't have to hassle with cleaning the filter cartridge weekly. Possibly something like this:
    http://www.walmart.com/ip/Intex-2650...681EG/39130771
    -Matt
    22,553
    That would be a good unit for your pool. You'll like the sand filter a lot better than the cartridge you're now using.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    I would recommend against that one. As you are now seeing, you have to replace the entire unit once one component goes bad. What if part goes bad sooner? It is an Intex after all. I would get the 2800 or 3000 gph sand filter and the SWG I have in my sig. The ECO models do not have copper in them anymore, so that is a major advantage in my books!
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Agreed, get the standalone SWG and a separate pump/sand filter.
    Pentair IC40 SWG
    Jun 2015
    Portland, OR
    4
    Thanks for the help all. I've got a new SWG coming, and hopefully will survive this season with my existing filter/pump and pick up a nice sand filter/pump when they go on clearance at the end of the season.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Wal Mart has one now for $130. I wouldn't expect to see them much less than that: Walmart: Intex Krystal Clear Sand Filter Pump
    This one is 2150 gph. I have the 1600 gph on my 16x48 pool, and it does fine. This one should be even better.
    Pentair IC40 SWG
    Jun 2015
    Portland, OR
    4
    Thanks Jeff. Picked one up yesterday at the local walmart and finished hooking it up in the dark last night. We'll see how the pool looks tonight when I get home.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Great! We love helping other people spend their money. But you'll never regret that purchase.
    Pentair IC40 SWG
