Results 1 to 8 of 8
Thread: Drained and refilled pool - looking for advice before adjusting levels
    vcarnett's Avatar
    May 2015
    austin/texas
    27
    Hello all.
    OK, I drained about half the pool and refilled (just reached full level this afternoon). The results, below, are from a couple of hours after reaching full (wanted to get a 3QT jug of bleach in it and let it circulate for a good hour. Circulated in filter bypass mode) Did the trick on the CYA but PH is really high (I'm assuming city water is high in PH). I'll do the research to see what needs to be done, but I wanted to post for advice to check my research and not screw this up. Help highly appreciated.
    PH: took 3 drops of R0005 to balance
    Chlorine: 1.4 ppm. Low. Added a 3 QT jug of liq bleach yesterday and another today - so 6 QTS in 2 days. Will add more tomorrow.
    TA: 50ppm (good)
    CH: 110ppm (low - quite surprised as our city water is very hard, or at least I thought it was). This # was 400 before drain/refill
    CYA: 40ppm (perfect)
    Thanks again for help
    Cheers
    p.s. After doing above test I let it circulate (filter bypass mode) a couple hours longer before applying the DE (I had backwashed while draining the other day)
    Anthony Sylvan 17k gal free form IG Gunite. 3' - 6'. Waterway SVL56 Pump. Pentair FNSP 48 (sq ') DE Filter (2013). Polaris 280 sweep w/Polaris PB4 booster. 2 skimmer intakes and 2 deep-end intakes. 4 returns. Pool Installed 2010. Filled from city water (Austin, TX - CH 50ppm. pH 9.0). Taylor k-2006 test kit. Currently running the pump 6 hrs / day.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Drained and refilled pool - looking for advice before adjusting levels
    Ok, looking good. What is your PH? Did you add muriatic acid to fix it? It is important to maintain PH between 7.2 and 7.8.
    Have you checked out the great articles in Pool School?
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jun 2014
    14,951
    When you do post your latest test results, it would be a good idea to also show us your CC reading. I don't see that above.
    vcarnett's Avatar
    May 2015
    austin/texas
    27
    Thanks for the replies.
    PH: I had to add 3 drops R0005 to get to desired (7.5). From the color it appeared to be above 8 (off the color scale). No, I have not added anything but Chlorine (liq Bleach) as I wanted to hear from you all first. I will get that going this evening.
    Honestly, I usually don't test CC--I did test it a few weeks ago and it was 0 -- since there's no one but me and my wife (and she only occasionally) in the pool. However, I will test that before posting in the future.
    Thanks again!
    vcarnett's Avatar
    May 2015
    austin/texas
    27
    Things are looking much better. This evening I added less than a quarter gal of MA (PH was ~8.2 ish) and 1 gal bleach (8.25% sodium hypochlorite) - was 1.2ppm.
    PH: 7.5
    Chlorine: 2.0 ppm. Still a tad low. Will add a gal tomorrow to get it ~3.
    CC: 0
    TA: 60 ppm (will test again tomorrow before adding ~ 4lbs Baking Soda - is that right?)
    CH: 130 - 140 (a little low).
    CYA: 45 ppm
    Thanks again for help!
    Cheers
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    You might want to test the calcium (CH) and pH in your tap water also, so you'll know what you're putting in when you top off the pool. Since you look like you have your testing down pat and a great knowledge of your pool (YAY!), you can start fine-tuning by bringing the CH up a bit. Your fill water test will help you know if your "normal" top offs this summer might help.
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    vcarnett's Avatar
    May 2015
    austin/texas
    27
    Sandra, great point - will test tap.
    Yes, I'm feeling much better about the process.
    Thanks!
    vcarnett's Avatar
    May 2015
    austin/texas
    27
    Test results from 6-16-15 after big rain (over an inch)
    FC 0
    CC 0
    pH 7.5
    TA 50
    CH 140
    CYA -40 (wow! Due to rain, I'm assuming)
    Added 96oz bleach (8.25%) to get that up. Will check in 30 minutes or so (pump is running) and add another (I'm sure it will need it). However, with cya so low I'm thinking chlorine won't hold.
