Thread: Major Mistake = Cloudy. Please Help.
    Jun 2014
    Austin, TX
    17
    I was all ready to do some pool chemistry today after some major rainfall activity. I measured the following this morning:
    FC: 0
    TAC: 0
    Salt: 2400
    hardness: 250
    CYA: 0
    TA: 50
    ph: 8
    So, I INTENDED to first put in 15 pounds of sodium bicarbonate. However, instead I mistakenly grabbed the sodium carbonate and added 10 pounds of it directly to the pool, pretty much all at once and then 5 pounds of sodium bicarbonate (containers looked the same). I saw it starting to get cloudy, but I figured it would quickly go away. I then added the 10 pounds of remaining sodium bicarbonate.
    The pool is extremely cloudy.
    I went ahead 4 hours later and put in 120 lbs of salt. I have a sense-and-dispense acid system, and pH is solid at 7.6.
    The pool is as milky as can be. What should I do to overcome my mistake and get rid of the cloudiness?
    IG Pool Size: 24,000 gallons
    Flagstone Decking, Pebble Plaster
    Cartridge Filter
    Date of pool build October 2014
    Spa , SWG
    Jun 2014
    14,965
    Re: Major Mistake = Cloudy. Please Help.
    Something tells me some of our veterans will have some pointers, but after seeing your numbers I was curious why adding some chlorine and stabilizer wasn't #1 on your list. Perhaps your SWG is just kicking in, but it may take a while. The last few days in our area have been brutal, so you may very well want to get some liquid bleach in there right away so you don't end-up fighting algae soon, along with the chemical situation. Start at about 2 ppm per day until you start to see CYA go up. Speaking of CYA, you need stabilizer ASAP! Use poolmath to push that up to about 40 using the sock method.
    Jun 2014
    Austin, TX
    17
    Quote Originally Posted by Texas Splash View Post
    Yes, I planned on addressing alkalinity first, and then I was going to add the salt and then the stabilizer (within the same afternoon). Unfortunately, I made the boneheaded mistake on the first step....
    Cartridge Filter
    Spa , SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You should always address PH and FC first. Don't worry about the TA.
    You will need to run pump 24/7 in filter mode.
    Lower PH to 7.2 using muratic acid.
    As for the cloudiness, I would bring FC to SLAM level and follow the SLAM process until you have clarity again.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    487
    just go to pool math and lower your ph, may take several applications of muriatic acid as your ph is probably way past 8ppm
    if it was 8 before your oops moment
    with pump running add 187 ounces of acid to start, wait half hour and retest and add more if required
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
