Thread: Generating chlorine, FINALLY!
    Jun 2015
    Toms River NJ
    6
    After receiving the the wrong generator then the shipping company delaying the replacement (2-day air came 6 day ground) I am finally generating chlorine.
    Unit is a Circupool SI-60 (60k gallon cell) and was painless to plumb in and wire up.
    I used 920lbs. of Morton Solar salt (blue bag, no additives) instead of pool salt because it was 3.00 a bag cheaper than pool salt (Home Depot). My only complaint was I got about 10 lbs of rocks out of the pool after dumping the bags. Bigger salt crystals took a little more work than pool salt to dissolve but no big deal. Just put in 6 bags at a time and pushed around with pool brush.
    If the Circupool unit lives up to the sales pitch I will be a happy camper.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Generating chlorine, FINALLY!
    Excellent, congrats on getting that done. I love my SWG.
    Here is a handy article about your water in case you haven't seen it yet.
    Pool School - Water Balance for SWGs
    and how about adding your pool info to your sig as shown here,
    Pool School - Read This BEFORE You Post
    laveenmoose's Avatar
    May 2012
    Laveen (Phoenix), AZ
    41
    If it's helpful, I've had my Circupool RJ30 for over 3 years and I love it, does exactly what they said it would
    10.5K IG gunnite pool with micro-pebble finish in Caribbean blue with Baja step. Haywood main filter with Perry's Pool Pump 1hp motor. Jandy CL-340 cartridge filter. Circupool RJ30 SWG system. TF100 test kit with Speedstir. Floating beer cooler.
    Jun 2015
    Toms River NJ
    6
    Thanks
    Quote Originally Posted by laveenmoose View Post
    THanks it does!
