Results 1 to 11 of 11
Thread: How are my numbers
    Jul 2013
    Waxahachie, Tx.
    446
    How are my numbers
    Hi everyone finally got good weather here in N. Texas and able to get stable testing w/o all the rain and drain.
    Just wanted to run some numbers by everyone since it says in pool school for a fiberglass pool to keep the CH between 220-320.Should I raise my CH from the 160 up to least 220?
    Or should I aim more for mid scale say 270?
    FC 5.5, CC 0
    PH 7.6
    CYA 75
    Wtr temp 90F
    TA 90
    CH 160
    Salt -3100
    Thanks for any replies I get. Just wanted to let everyone know that my first year of pool ownership has been a pleasant experience, thanks to all the wonderful help here on TFP.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: How are my numbers
    Does your pool have a vinyl liner in it per chance?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Test your tap water. When things start getting really hot and you start losing water to evaporation, your CH will climb all by itself. Water evaporates, CH stays behind.
    Unless the pool is brand new and under warranty and you have to keep CH up to protect the gelcoat, I'd just wait for it to happen naturally.
    Jun 2014
    15,140
    Hey there fellow "Viking". Our water is quite hard in my area near San Antonio. You must get the good stuff up north.
    Jul 2013
    Waxahachie, Tx.
    446
    Love my viking. First year ch stayed in the 240 range.
    I tested my fill water last year but remember what the results were. I normally document everything. I will have to retest.
    Should i go ahead and add calcium
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Quote Originally Posted by woodyp View Post
    Im pretty sure the FG in his sig means fiberglass.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jul 2013
    Waxahachie, Tx.
    446
    Your right. Fg...fiberglass
    Jun 2014
    15,140
    As Richard mentioned above, CH should begin to climb naturally via evaporation. But if you are concerned about meeting the requirements outlined in the Viking owners manual to protect your coating, and your pool is fairly new, you certainly can bump it up a bit. If you do, I would recommend going to the lowest amount noted in the owners manual by using the Poolmath calculator to determine the amount required to reach that level. Over time, that number may continue to climb, and if it gets too high you don't have many options to lower it again. Have a great summer!
    Jul 2013
    Waxahachie, Tx.
    446
    Thanks for all the input. I learned something new in this discussion. I did not know that ch raises naturally due to evaporation. This is why i like this forum. Everyone is eager to help and provides a lot of useful info. I will do 2 things. First test my fill water ch level. Then make a decision based on that test.
    Thanls again for everything.
    Jun 2014
    15,140
    You got it! PS ~ We ALL learn a bit here everyday. It's what makes this forum so good.
    Jul 2013
    Waxahachie, Tx.
    446
    Tested my fill water CH @ 160.
