Thread: Testing ta
    Jun 2015
    belleville mi
    7
    Testing ta
    Is it normal for the ta to rise during a slam mine went from 100 to 150 in 5days still not perfect clear don't know if I am doing something wrong , going to do a over night test .
    Ester Williams vinyl liner 24ft. Round above ground 13500 gal. Hayward pro series sand filter , Hayward 1.0 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Re: Testing ta
    If you have hard water and you had to add a bunch after backwashing, that could account for it.
    You really shouldn't worry about anything but FC & CC until the SLAM is complete. As you've experienced, eradicating algae is a lengthy process. Fixing the rest can be done in a couple hours once the water is clear and FC levels drop back from shock to normal.
