Thread: Nature2 Express mineral removal
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    So I had seen the thread about emptying standard Nature2 cartridges but mine that was inherited with the pool turned out to be something called Nature2 express. It's fully enclosed, no separate cartridge inside the housing.
    So I decided to just drill it out and empty. 3/16"drill bit and took out the bottom grids.
    Was careful not to break the center column. Turned it over and shook all the metal balls out. There was some foam material in there, pulled that out with a pliers then everything came out quicker.
    I chipped the threads in my enthusiasm but it installed back in empty just fine.
    No leaks!
    # Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Nature2 Express mineral removal
    Save those beads.
    Find some Nature2 proponent and toss them in his pool.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    normally you would just replace the Nature2 express with a new cartridge approx every 6 months.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by malcolmb5325 View Post
    I'd rather not have metals in my pool and they're a waste of money. That's the point.
    Feb 2014
    Central Minnesota
    5,080
    Mispost...
