Thread: First Test Results
    Jun 2015
    Cedar Run NJ
    17
    First Test Results
    Hello All, Received my TF-100 today and here are results
    CL-2
    BR-4
    PH-6.8
    FC-3.5
    CC-1
    TC-4.5
    CH-275
    TA-50
    CYA-30
    Plugged in numbers and printed recommended adjustments, my question is where to start lol. I'm new here and would appreciate all the help I can get. Also my pool is crystal if that helps.
    Thank You for your help
    17x37 IG 20,000 gallons Pro Grid DE Hayward filter, Lighted waterfall with slide use BBB.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: First Test Results
    Congrats on your TF 100
    PH and FC are low.
    CC is high.
    You need to raise PH to 7.4
    How does your water look?
    Oops I see water is crystal clear.
    Once you add bleach and bring PH up the CC should come down
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    Cedar Run NJ
    17
    Thanks for your quick reply!! Should I use Borax and do I mix and put through skimmer?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Yankee,
    your pH needs to come up a bit.
    Your FC at 3.5 with CYA of 30 is fine.
    Using Borax to raise your pH will slightly raise your TA, which is ok. I wouldnt worry about intentionally adjusting TA right now.
    wait a bit and see how yoru pH reacts and how often you have to adjust it. test it every day or 2 over a couple of week period and if you have to adjust pH often, then consider making adjustment to it.
    You could consider raising your CYA a bit if you want to, but 30 is fine if it suits you.
    If you would add which type of surface you have (plaster, vinyl, fiberglass), they surface type matters and it would help us help you.
    Also, add how you chlorineate the pool...i.e, SWG or liquid chlorine. That matters too.
    Divin Dave,
    Jun 2014
    15,156
    Glad to see you got that kit! Now YOU are in control. Outstanding.
    Jun 2015
    Cedar Run NJ
    17
    Once again Thanks, I have stopped using pucks and now use bleach(little over a week now) and surface is vinyl.
