Results 1 to 11 of 11
Thread: Where do you buy your cyanuric acid?
    May 2015
    Atlanta-GA-
    69
    Hi
    I am new at this. I was looking on amazon to buy my Cyanuric acid. Can I go with the cheapest? Some are 8lbs and some are 25lbs,I have a 12' above ground pool, how much do I need? Any preferred brand?
    Thxs
    Pat
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Where do you buy your cyanuric acid?
    Unless you have Amazon Prime with free shipping, just go to Walmart and buy it. You'll be there buying pool toys anyway.
    How deep is the pool? Pool volume determines how much you need. Hint: for a small pool like yours, roughly a pound should be enough.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Get mine at Walmart.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I usually buy mine at Lowes, but I hear the stuff at Wal-Mart dissolves a little faster
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Lowes for me too, they just switched from Kemtech to Clorox brand.
    Apr 2010
    Central NJ
    227
    I always buy mine at walmart, and it's called "Stabilizer". If you look at the ingredients, you will CYA.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I've only had to buy it once. I got it at walmart. Ours just switched from aqua chem to clorox brand. Wasn't very expensive and dissolved very easily.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Ellington, CT
    262
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    May 2015
    Atlanta-GA-
    69
    Thanks to all for the suggestions. I will try walmart first, I think the best deal would be there. But I will look at the one at lowes next time I m over there.
    Patrick
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Walmart...its like $14
    Lomart 18x48 AGP 7000Gal
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    TF-100 w/Speedstir!
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I bought mine from my local pool store. Although I am very fortunate to have a real good one close by. I've had to buy it twice this year. I kept my CYA level low last year (30) and we had several heavy rains that required me to to drain back to normal levels. Lost just about all of my CYA and a good chunk of my calcium hardness too.
    I paid $25 for a gallon of liquid CYA. That same amount in granules (4 lbs) would have cost me $19. The extra $6 was worth it to pour it in and have it dissolved within 30 seconds instead of waiting a week for granules to dissolve.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
